11-13-2017, 11:57 AM   #31
QuoteOriginally posted by peterh337 Quote
Picking up an old thread...
I have a brand new Zeiss Milvus 18mm f2.8 converted from Nikon to Pentax, as per this thread
Is there a high quality compact prime around 17-18mm for K1? - Page 7 - PentaxForums.com
I must be missing something obvious because the camera does exactly nothing. I have it set to M and manual focus, but all I see is a flashing "F--" indication on the LCD and half-pressing the shutter does nothing too. No focus confirmation and the shutter does not work.
You need to go to Settings menu - Custom - page 4, option 26 - Using aperture ring - switch to Enable. Now camera will release the shutter. Focus confirmation should work also, I'm using few m42 lenses that way with K-1.
Curious - does Milvus achieve infinity focus with the conversion? And how much does conversion cost if it does? Would it work for any manual prime with a nikon mount?
11-14-2017, 01:06 AM   #32
Thanks. I found the aperture ring setting and that stops the F-- flashing.
However I cannot find anything in the K1 menus which configures what these articles call the Green Button. I found the green button function (in M mode) here
Pentax K-1 Review | PhotographyBLOG
Interesting there appears to be no "light meter" feature but with the green button you don't really need one.
Yes - infinity focus works fine. I am shooting some pics now.
Original (screenshot from Lightroom)
1:1 (not perfect focus as it was handheld)
After lens correction - there is no LR profile for the 18mm Milvus so I looked around the others and the Distagon ZF2 looks OK
BTW, LR lens profiles can be transferred easily between LR installations. You can even go from LR6 to LR3. I have an old LR3 running on a winXP machine. So if anyone has the profile, please let me have it
This is with the vignetting slider moved to 160%
The lens correction also does a bit of barrel or pincushion so it would be better to get it right... this lens has a very low level of distortion by itself so maybe just doing vignetting manually would be enough. Of course, on a landscape shot you can't see geometric distortion anyway
The thread which led me here was this
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/336643-the...18mm-k1-7.html
The conversion was about 100 euros plus shipping from Spain back to the UK. The lens was rather more...
This image is without any lens correction but with vignetting applied to the max level of 100%
11-14-2017, 12:16 PM   #33
A slightly better example...
Original image
After correction in LR6 with the actual lens profile
I reckon the vignetting is not fully corrected above.
1:1 centre
1:1 edge
Very little visible chromatic aberration, and the foliage in the last pic is a lot nearer the camera so out of focus.
aperture, button, camera, dslr, focus, focus lens, full frame, full-frame, k-1, k1, lens, meter, olympus, pentax, pentax k-1, tripod
Some questions about using manual focus lenses on K-3 II sarge Pentax SLR Lens Discussion 7 08-31-2016 01:34 PM
Issue with manual focus on 60-250 when using Pentax 1.4x TC Quich Pentax SLR Lens Discussion 11 12-28-2015 07:56 PM
Macro Using catch in focus on manual lens with macro extension tubes Blueberrybob Photographic Technique 8 08-01-2015 07:53 AM
Using a Manual Focus lens with a Pentax K-3 DawnHoweth Pentax SLR Lens Discussion 13 06-22-2014 02:13 PM
DOF in Using a Manual Focus Lens on a DSLR zx-m Pentax DSLR Discussion 42 11-25-2009 12:51 AM
All times are GMT -7. The time now is 06:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
