09-08-2016, 10:34 AM   #1
raw+jpeg
This is one of those problems that likely has an easy answer that I just can't see. When I set my K1 to raw plus jpeg, or dng plus jpeg, it doesn't appear to save the jpeg. The estimated space on the card goes down, but I see no jpegs in Lightroom when I go to download unless I have shot jpegs only. If I tell the camera to save the jpegs to the second card then fine, it will shoot raw plus jpeg. Is that how it is supposed to work?
Thanks,
John
09-08-2016, 10:43 AM - 1 Like   #2
This sounds like it could be an issue with Lightroom. When shooting in RAW+, are you seeing both formats when accessing the card directly?
09-08-2016, 10:46 AM - 1 Like   #3
QuoteOriginally posted by johnkrumm Quote
Did you see JPEG files in the card if you view the content on computer directly? Lightroom imports raw only if JPG files are in the same location.
09-08-2016, 10:54 AM   #4
Ah, good suggestion from both of you. There they are. So I'll poke around in Lightroom to see what I'm doing wrong.
---------- Post added 09-08-16 at 11:11 AM ----------
I think I have it figured out. I had to check "treat jpegs as separate files" in Lightroom. Took me a bit... Thanks for the help.
09-08-2016, 01:08 PM   #5
aleonx3's Avatar
If both RAW and JPG files are in the same folder, both have the same file name except for the extensions. Lightroom will import the RAW file and leave the JPG file untouched.
card, dslr, full frame, full-frame, jpeg, jpegs, k-1, k1, lightroom, pentax k-1
Different exposure between RAW and JPEG in RAW + JPEG - possible? BigMackCam Pentax DSLR Discussion 15 10-08-2016 01:50 AM
Raw + jpeg versus embedded jpeg cpk Pentax DSLR Discussion 20 12-23-2014 08:44 AM
how to separate raw & jpeg after shooting raw + nutkasse Digital Processing, Software, and Printing 21 02-05-2013 07:54 PM
JPEG, RAW, JPEG + RAW...huh? Raptorman Troubleshooting and Beginner Help 14 12-22-2009 11:49 AM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
All times are GMT -7. The time now is 04:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
