09-18-2016, 12:01 PM   #1
acoufap's Avatar
K-1 - number of AF points shown in A-33 mode
Hi everybody, at the moment I'm a little bit confused.
Usually I only use Spot as autofocus mode. Now I tried the other possibilities SEL1, A-9 and A-33.
When pushing AF mode button and spinning the back dial the modes SEL1 and A-9 the AF points are shown properly in the viewfinder. But A-33 is represented only by 15 AF points. Same when using the back display for selection.
Is this ok?
Maybe the shown number of visible AF points depend on an additional other setting?
Any ideas? - Thanks in advance!
P.s. Firmware 1.20
---------- Post added 2016-09-18 at 20:25 ----------
Just did another test. I changed the attached lens. The problem occurs using the HD DA15.
Now I attached the DA18-135. And what shall I say. All autofocus points are shown!
So it has something to do with the attached lens?! - Any similar observations and/or explanation?
09-18-2016, 12:30 PM   #2
Tjompen1968's Avatar
When you put on the DA15, does the camera go into Crop mode?
09-18-2016, 12:34 PM   #3
acoufap's Avatar
QuoteOriginally posted by Tjompen1968 Quote
same behaviour in crop and ff mode
---------- Post added 2016-09-18 at 20:39 ----------
checked the mount. DA15 is KAF, DA18-135 is KAF3. Maybe this is the reason?
---------- Post added 2016-09-18 at 20:49 ----------
KAF shouldn't be the reason. My DFA100WR uses also the KAF mount. No problem - all AF points are shown.
09-19-2016, 10:12 AM   #4
acoufap's Avatar
Anybody who owns a K-1 and DA15 and would like to do me the favour to try if there's the same behavior in A-33 mode?
If the whole 33 focus points are visible, I know that my DA15 has a small issue.
af, autofocus, crop, da15, dslr, full frame, full-frame, k-1, k1, kaf, mode, mount, pentax k-1, post, reason
Use of Manual mode Vivitar 283 Flash vs PTTL Metz 50 AF-1 with the Pentax K-S2 krgroothuis Pentax DSLR Discussion 5 06-06-2016 12:54 PM
K-1 AF in video mode i83N Pentax K-1 18 04-01-2016 04:01 AM
Sony a6300 Boasts the World’s Fastest AF and Highest Number of AF Points osv Non-Pentax Cameras: Canon, Nikon, etc. 23 02-27-2016 11:12 AM
K30 - reduce number of AF points bin Pentax K-30 & K-50 6 12-14-2013 06:38 AM
help - TAv shown instead of M mode Breanne Visitors' Center 2 10-28-2013 08:16 PM
All times are GMT -7. The time now is 12:33 AM. | See also: NikonForums.com, part of our network of photo forums!
