09-20-2016, 07:18 AM   #1
Pentax 1.4 converter on the 70-200 with K1
The reviews I have read on the Pentax 1.4x teleconverter give it good reviews, but will it work with the K1 without vignetting? Say with the 70-200, and 150-450?
It's one of the more expensive 1.4 converters on the market, but if vignettes a lot with the the 70-200, I guess I will have to wait for Pentax to come out with a new version. Or is there a good non Pentax version others are using?
Thanks
Paul C
09-20-2016, 08:36 AM   #2
Emperor and Senpai
VoiceOfReason's Avatar
The 1.4 will vignette badly when used on the K1 unless you use it in crop mode. Every lens I've tried it with on the K1 is the same.
09-20-2016, 08:55 AM   #3
aleonx3's Avatar
If I am not mistaken, isn't the HD DA-1.4 converter designed mainly for the crop sensor? Perhaps the older version non-HD FA converter may work on K-1 in FF mode.
09-20-2016, 09:10 AM   #4
QuoteOriginally posted by aleonx3 Quote
Yes it's designed for the crop sensor, but many of the lenses for crop only work fine with the K1, 200mm and 300mm for example. I was hoping the 1.4 would also. but appears it won't.
Paul C
09-20-2016, 02:56 PM   #5
QuoteOriginally posted by VoiceOfReason Quote
Not my experience with the Pentax D-FA 150-450 lens.
I use the 1.4x TC with the 150-450 on the K-1 and it does vignette, but only very little. It is no trouble to extract a good image that is quite a bit larger than the crop mode image.
Cheers,
Terry
09-21-2016, 12:00 AM   #6
I have the same experience with the DA* 300 and 1.4 TC in FF mode, the corners are a bit darker at the edges, but it is perfectly usable.
09-21-2016, 01:17 AM   #7
redpit's Avatar
https://www.pentaxforums.com/forums/190-pentax-k-1/314413-post-your-k-1-pictu...ml#post3634452
This should answer your question. I would wait for a FF converter unless you really need it now.
09-21-2016, 04:54 AM   #8
QuoteOriginally posted by tduell Quote
Cheers,
Terry
I can confirm this, the corners are black at the longer end but you don't have to crop much. I'd say it's clearly better than with the 60-250 without surgery.
dslr, full frame, full-frame, k-1, k1, pentax, pentax 1.4 converter, pentax k-1, reviews, version
K-1 with 60-250 f/4, Pentax 1.4 HD APS-C converter and Tamron 1.4X Pz-AF MC4 Teleconv pizzamaker74 Pentax Full Frame 2 09-12-2016 03:53 AM
Lens tests on K-1 : 15-30, 24-70, 70-200, 31, 43, 77, 100 Macro, 28-70 and 80-200 Mistral75 Pentax SLR Lens Discussion 14 06-28-2016 11:46 AM
K1 sample with 70-200 zmohie Pentax K-1 2 03-01-2016 06:48 PM
DA* 50-135 with HD 1.4x converter, or 70-200 f2.8??? nms_photog Pentax SLR Lens Discussion 15 07-18-2015 03:36 PM
New 1.4 rear converter and Sigma 70-200 (2.8) ? tmacdon Pentax SLR Lens Discussion 4 03-19-2014 03:09 PM
All times are GMT -7. The time now is 05:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
