09-24-2016, 11:50 AM   #1
Pixel Shift - OK To Leave MC On All The Time?
At times I need to change to Pixel Shift quickly and have the Fx1 button set to do this. However, when I do that it sets to PS MC consistently and I can't find a way to change it so it sets to PS non-MC. It's more cumbersome and time consuming to then have to go into menu C3 and turn off MC. Thus, I'm shooting a considerable percentage of my photos (landscapes) with MC on even though there is no motion. Is there any downside to leaving the PS MC setting on full time and using it for scenes where there is no motion and MC is not needed (other than the increased processing time). I assume there is no positive effect from this but is there any deleterious effect on the image from use of MC when there is no motion and no need to use it?
The owners manual doesn't address this specific question, at least not that I could find. A search of this forum revealed a thread involving the same question but I didn't find a definite answer, at least as I interpreted the responses.
Thanks for any help.
09-24-2016, 11:56 AM   #2
ffking's Avatar
It's not so onerous to change to and from PS on the info screen (as against menu) is it? - You have full options there
09-24-2016, 12:03 PM   #3
MJKoski's Avatar
You can change the PS mode from the same menu where you set the custom buttons. It is ass-designed but when you map PS to function button you can alter the default mode which is selected. It is a submenu of the PS selection where you do this.
If you use adobe converter, better disable motion correction.
09-24-2016, 12:09 PM   #4
If you shot RAW, it does not matter whether you select MC or not, since you can select MC or non MC, or no pixel shift as an option for the RAW conversion.
09-24-2016, 12:13 PM   #5
MJKoski's Avatar
Not with Lightroom or Photoshop.
09-24-2016, 01:11 PM - 1 Like   #6
I use MC - on all the time. Sometimes i take photos with black fabric background that in MC - off mode produces moire. MC - on setting reduce moire. Overall, with MC - on i get much better results. MC off demands really "stable" conditions and no move at all. (Sorry for my bad english).
09-24-2016, 01:42 PM   #7
microlight's Avatar
The PS motion correction is on by default and can't be turned off in-camera with the K-3II (switchable in DCU5) so I can't think why it would do any harm.
09-24-2016, 03:32 PM - 1 Like   #8
It adds a little bit of processing time, but generally-speaking, it's probably safe just to leave it on.
09-24-2016, 03:43 PM   #9
todd's Avatar
QuoteOriginally posted by MJKoski Quote
Confirmed.. Curiosity got me and it's there...
09-24-2016, 04:21 PM   #10
MJKoski's Avatar
Ya it is there. And MC should be turned off when using Adobe stuff. Otherwise it will result in nasty artifacts in places which would not be so severe without.
09-24-2016, 04:53 PM   #11
Not just Adobe but any program if you are processing the OOC JPG with PSR MC on incamera or RAW processed through PDCU with MC on. Sharpening, especially extreme, will probably over exaggerate the artifacts. Processing RAW PSR should not suffer.
RONC
09-24-2016, 05:30 PM   #12
MJKoski's Avatar
Should not but the unfortunate thing is that Adobe fails completely with RAW files where MC is ON. And as I refuse to use MC I will take separate shots with PS ON/OFF and then just blend in the details in Photoshop.
Dpreview has nice comparison page: https://www.dpreview.com/reviews/k1-pixel-shift-resolution-updated-field-test
Adobe goes wonky. False color all over the place. Now if you switch off MC, false color will not spread around so badly making it easier to blend details where they are needed. SilkyPix seems to do nice work with MC but I cannot stand the user interface and workflow obstacle.
09-24-2016, 07:53 PM   #13
Dpreview has nice comparison page: Pentax K-1 Pixel Shift Resolution: Updated Field Test: Digital Photography Review
Adobe or any other program processing that file will go wonky. It is not just Photoshop that does it. Photoshop and Lightroom do not compensate for movement within the subject. Only PDCU and in camera processing attempt to.
Have you tried any other programs.
Adobe ACR programs and PDCU are the only commercial programs that composite Pixel Shift files.
RONC
09-25-2016, 03:46 AM   #14
acoufap's Avatar
Thanks - interesting article!
09-25-2016, 04:32 AM   #15
QuoteOriginally posted by todd Quote
This is strange but in C5 Fx1Button Customization my F-1 doesn't show the same screen- it has only the off - arrow - MC option so I can't change the default to non-MC. Same for the Fx2 button. I wonder why the difference. I have't updated the camera software yet, perhaps that's why??
---------- Post added 09-25-16 at 05:41 AM ----------
Thanks to everyone for your replies. It seems MC does cause more problems in PP than non-MC? If so this could be a reason not to use MC if there isn't motion (in my case the motion is usually in foliage due to wind, which we've had a lot of in the northern Rockies this fall). I shot some fall color scenes yesterday without much wind using both MC and non-MC for comparison and will look at them today. I use PSE14 and assume it has the same problem with PSR files as Photoshop and LR (haven't yet tried it with any PSR files).
change, dslr, effect, full frame, full-frame, k-1, k1, mc, motion, pentax k-1, pixel shift ok, question, shift, time, wind
Alternative to the appalling SilkyPix for pixel-shift GrantFS Digital Processing, Software, and Printing 31 10-08-2016 04:36 PM
Does the K1 Allow Us to Turn Pixel-Shift ON and Remain On when Camera Restarts? MichaelErlewine Pentax K-1 4 06-01-2016 03:14 AM
Pixel Shift on the K-1 Tjompen1968 Pentax K-1 45 05-25-2016 10:30 AM
Renting a K-3 II for the weekend to test out Pixel Shift Zen4Life Pentax K-3 55 03-29-2016 04:08 PM
GT1544T, GT2541, Which tripod should I buy to match the K3 II pixel shift mmhhdmj Pentax K-3 18 11-22-2015 06:40 PM
All times are GMT -7. The time now is 08:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
