09-26-2016, 05:42 AM - 2 Likes   #1
fwbigd's Avatar
HSS With Pentax K-1+Cactus V6ii and Godox 360
Had the pleasure of working with a beautiful young lady last week, so I decided to try out some shots using HSS with the K-1+Cactus V6ii and the Godox 360. Three things I learned from the shoot were expose for the background, adjust the power of the flash to match the back ground exposure and use contrast detection AF (live view).
All photos shot wtih FA* 85mm f1.4.
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
09-26-2016, 09:14 AM   #2
kenspo's Avatar
Im still struggling to make the V6ii to work with Pentax and Godox..haha..but nice pics
09-26-2016, 12:23 PM   #3
dcpropilot's Avatar
When is Godox going to release the R2 with TTL and HSS compatibility with Pentax?
09-26-2016, 02:19 PM   #4
fwbigd's Avatar
QuoteOriginally posted by dcpropilot Quote
Very good question. I contacted Adorama about a month ago and they still didn't have an update on when it would be available.
---------- Post added 09-26-2016 at 04:22 PM ----------
QuoteOriginally posted by kenspo Quote
Im
This thread might help you understand how to get the V6ii to work with Godox flashes. https://www.pentaxforums.com/forums/125-flashes-lighting-studio/327358-pentax...ml#post3733529
09-27-2016, 04:27 AM   #5
Class A's Avatar
QuoteOriginally posted by fwbigd Quote
Ooh, I assume "HSS" is for Hot Super Sweetie.
Thanks for sharing!
I see some advanced hand modelling. Did she do that on her own or did you instruct her?
09-27-2016, 04:36 AM   #6
Class A's Avatar
Im still struggling to make the V6ii to work with Pentax and Godox...
Shouldn't be that hard.
What Godox flashes are you using?
There are two different approaches with flashes that have a different native radio trigger system:
  1. One V6II on the camera as an "HSS enabler". Fwbigd used this approach. Just choose the "flash system" depending on what camera system the Godox trigger was made for. Choose "MANUAL" for a simple trigger like the FT16. Put the trigger on top of the V6II.
  2. One V6II on the camera and another V6II as a receiver attached to the flash/strobe. If the flash/strobe does not have an ISO hot-shoe foot then you'll need a sync-cable (audio cable with 3.5mm plugs will do). This latter approach would support turning individual lights on and off with the V6II on the camera and you don't have a "tower of triggers".
Make sure to update the firmware on your V6II to the latest version. The initial firmware version was a bit buggy and one of the bugs required the selection of the "Nikon" flash profile for the on-camera V6II to make a trigger-on-trigger solution (1. above) work when the trigger was simple, like the FT16.
P.S.: Forgot to mention that you have to engage HSS mode on your Godox flash/strobe manually.
09-27-2016, 11:32 AM   #7
kenspo's Avatar
I have the AD360's..but thank you! Will give it a try ^^
09-27-2016, 01:40 PM   #8
Hello
interesting pictures.
Wish lens is it?
I can't find a pentax 85mm f1.4.
Right?
Greetings
09-27-2016, 02:03 PM   #9
Thanks fwbigd,
I would love to know more about what you did here. What mode was the camera in? Why did you choose to to use Live View?
So, I have been following information on the new Cactus triggers, but not closely. I know that the Cactus V6 ii have two HSS modes, one that just fires the flash at full power, and another that works differently. Does it actually work like a Pentax P-TTL flash, or are you able to set the power output? What I would love to be able to do is use my Camera in AV mode as I usually do, and be able to adjust flash power manually with shutter speeds of faster than 1/200th.
09-27-2016, 07:57 PM   #10
Class A's Avatar
QuoteOriginally posted by Mr.Alan Quote
Wish lens is it?
The Pentax FA* 85mm f/1.4 is a legacy lens that is no longer in production but of course still usable on a modern Pentax DSLR.
09-27-2016, 08:03 PM   #11
Class A's Avatar
QuoteOriginally posted by jake14mw Quote
The V6II is a manual trigger. You can control up to four groups, each having its individual power level that you control manually (using a dial).
There is no P-TTL support other than HSS (for supported flashes), and "P-TTL pass-through" to allow having a V6II sandwiched between a camera and an on-camera flash, without losing the P-TTL features of the on-camera flash.
You can do that with the V6II, as long as you are using any of supported flashes (which need not be from Pentax).
09-27-2016, 08:19 PM   #12
Class A's Avatar
I'm pretty sure that you'll have to manually engage HSS on the AD360. I understand there is some button combination to do that.
09-28-2016, 04:51 AM   #13
Thanks Class A, has anyone done a write up or video explaining the use of the Cactus V6 ii for HSS with Pentax?
09-29-2016, 09:28 AM   #14
I notice on the Cactus site that for the V6 is lists the Nikon SB-28 as supported, but for the V6 ii it does not. Is that correct?
09-30-2016, 05:11 AM   #15
Class A's Avatar
I don't know, but there isn't much to it anyhow.
The V6II has an auto-detect mode so if you put it on a Pentax, it will automatically set the flash system to "Pentax". With an RF60 as an off-camera flash, you can first away immediately, with other flashes you may have to select their profile on the V6II receiver first. However most flashes will be auto-detected by a V6II receiver, so normally it should just be "plug and play".
Only when you start using strobes, or flashes with proprietary triggering systems that are not directly supported by the V6II, it gets more involved. There are a couple of not too complicated workarounds for such situations, but as I said for supported flashes using HSS is really simple.
Yes, that's correct.
The SB-28 only supports analogue TTL. The V6 supports analogue TTL but the V6II does not.
Cactus said they will release a firmware updated for the V6 in October that will make the V6 compatible with the V6II. You'll then be able to fire an SB-28 sitting on a V6 by using a V6II transmitter. However, HSS will not be supported in this configuration. Only normal shooting and PowerSync.
cactus, dslr, full frame, full-frame, godox, hss, hss with pentax, k-1, k-1 cactus v6ii, k1, pentax k-1, pentax k-1 cactus, v6ii, v6ii and godox
Pentax HSS with Cactus V6ii and Godox Witstro AD360 Flash Light Speedlite fwbigd Flashes, Lighting, and Studio 89 04-23-2017 07:37 PM
Second courtain sync or strobe - Cactus v6II plus any Pentax 360/540 I or II gabriels Flashes, Lighting, and Studio 8 09-21-2016 02:52 AM
Cactus RF60 and Cactus V6II with Pentax K1 gsande2016 Flashes, Lighting, and Studio 3 09-16-2016 02:24 PM
Cactus V6ii - cross brand compatible HSS tomO2013 Flashes, Lighting, and Studio 135 09-08-2016 07:17 PM
HSS with Cactus V6 II and Godox Ving 850s with Pentax 645D/Z howieb101 Pentax Medium Format 2 08-16-2016 07:30 PM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
