10-05-2016, 07:27 AM   #1
Pentax Adapter K for 645 Lens (645 to K mount) Read more at: http://www.pentaxforums
Guys,
Who can tell may my K-1 work with 645 lenses using Pentax Adapter K for 645 Lens (645 to K mount)...?
Thank you !
Nick Uplander
10-05-2016, 07:48 AM   #2
Well, I have the adapter, mounted it to my 645 400mm, tried to mount to my K-1 and wound up scratching the paint on the camera body because the screw ( I assume it's some sort of locking screw) on the adapter didn't clear the camera body at the prism. Maybe the screw could be removed but proceed with caution.
10-05-2016, 08:57 AM   #3
I believe the adapter allows you to rotate the mount so that the screw is on a different part of the mount, and therefore will not contact the overhanging pentaprism area.
10-05-2016, 08:59 AM   #4
I've been using a Mamiya 645 Lens to K-mount adapter - that works as intended. There's no magic and no rocket science involved, and it's totally ununderstandable how such a beast (albeit for Pentax 645 instead of Mamiya 645 mount) should scratch a camera. The rear end (that's the one that goes into the K-1) is identical between these two.
There's one little caveat. Should you be using the adapter in conjunction with Pentax's 1.7x AF teleconverter, you should ascertain that the adapter is electrically conductive. If not, the camera doesn't detect a lens mounted to the teleconverter and the AF won't operate.
10-05-2016, 09:40 AM - 1 Like   #5
Ive used the adapter and it works well. There are a few things to note. The adapter spins so that the screw on it will not hit the pentiprism as leekil mentions. Also the lens needs an aperture ring so lenses such as the dfa 55 will not work.
10-05-2016, 11:41 AM - 1 Like   #6
QuoteOriginally posted by Uplander Quote
Guys,
Thank you !
Nick Uplander
It is also possible to use a MIREX tilt/shift adapter for Pentax 645 lenses instead of the original Pentax 645 Adapter (MIREX-Adapter f). The current version did fit to all APS-C Pentax Cameras but not to the K-1.
A new version is under development.
adapter, dslr, full frame, full-frame, k-1, k1, lens, pentax, pentax adapter, pentax k-1
Pentax K lens to Pentax 645 mount adapter PhilRich Pentax Medium Format 9 09-28-2016 12:18 PM
645 lens to K-mount camera adapter with AF? zzeitg Pentax SLR Lens Discussion 7 05-11-2015 05:50 PM
Contest #101 - January 2015 (Best of 2014) Read more at: http://www.pentaxforums.com rosserx Monthly Photo Contests 2 02-08-2015 08:36 AM
Weekly Challenge Picture of the Week POTW #316 25 May-08 June 2014 Read more at: http://www.pentaxfor cif Weekly Photo Challenges 17 06-22-2014 07:38 PM
All times are GMT -7. The time now is 03:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
