10-07-2016, 05:51 PM   #1
Miguel's Avatar
Control Panel as default LCD screen?
Just got the K-1 and so far so good. Is there a way to have the control panel serve as the default LCD screen as the camera starts up? Even better, is there a setting to enable no screen to appear unless I press the Info or Menu buttons?
Thanks,
M
10-07-2016, 05:55 PM   #2
UncleVanya's Avatar
QuoteOriginally posted by Miguel Quote
Thanks,
M
On past bodies if you press info info then you can select the screen you want one of which is "off". It remains off through power cycles until you change it.
10-07-2016, 05:59 PM   #3
Yup, this still applies to the K-1.
You have to press the button to pull up the control panel, though.
10-08-2016, 08:43 AM   #4
Miguel's Avatar
That works just fine. Thank you both.
M
control, control panel, default, default lcd, dslr, full frame, full-frame, k-1, k1, lcd, panel, panel as default, pentax k-1, screen
LCD Panel Issue sasikantt Pentax DSLR Discussion 3 06-28-2011 09:30 AM
Does Kr use same LCD screen as K5 and K7? texoma Pentax DSLR Discussion 7 01-24-2011 12:15 AM
Can't display control panel. velvia Pentax K-5 & K-5 II 4 12-30-2010 03:12 PM
Info on LCD panel davduck53 Troubleshooting and Beginner Help 3 03-05-2010 10:19 AM
All times are GMT -7. The time now is 09:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
