10-17-2016, 12:26 PM   #31
QuoteOriginally posted by Qwntm Quote
This might also account for the poster who said his birding shots had slow AF. If your waiting around for the birds to show up, the camera could power off. I'm still testing all this but it seems to be the reason for my issue so far...
Not sure about this. When I receive the K1 , during the first couple of weeks I tested it, I saw this hesitating AF randomly occurring, especially in low light. Now I'm not experiencing it anymore, and I don't know why.
10-17-2016, 12:29 PM   #32
UncleVanya's Avatar
I think I figured out the AF delay.
I had the K1 set to "Auto Power Off: 1 Minute." Which usually is no big deal because when you are using the camera it usually stays on while you are using it. But at a wedding there are times when you stand around for 5 minutes or more without touching the camera between shots. If the camera "Auto's Off" it there is a delay while it is restarting and the AF has a lag time. If the camera is awake, the AF is pretty much instant even in dim light.
So next wedding, Auto Power Off will be set to "Off" and we'll see how we go.
Is there a setting between 1 and infinity? Maybe 30 mins?
Nice to hear you are finding the problem that related to your issues and it seems easy to correct.
10-17-2016, 12:35 PM   #33
Tjompen1968's Avatar
Minutes 1, 3, 5, 10, 30 and OFF are available.
10-17-2016, 12:49 PM   #34
MJKoski's Avatar
It is the bubblegum tamron lens which fails there. It is unknown whether the AF somehow tries to fix focus shift by stopping down when focusing or not but anyway my 24-70 was very sluggish compared to tamron 24-70 on D810 which I tried out when trying to find an alternate to Nikkor 24-70.
If focus shift is worked around by stopping down when focusing there is not that much light available to AF module anymore and focusing becomes very sluggish.
10-17-2016, 12:55 PM   #35
QuoteOriginally posted by MJKoski Quote
It does not stop down. It calculates where to set focus according to choosen aperture.
10-17-2016, 01:15 PM   #36
All the metering data is there in the K-1/K-3/645Z EXIF. Abundantly so.
That EXIF data lets you reconstruct with a great deal of precision exactly what the K-1 metering sensor sees, like so:
And the above represents only about 20% of the data the Pentax RGB sensor records.
Interesting. I would like to know just how much detail the RGB sensor is cable of.
10-17-2016, 02:03 PM   #37
QuoteOriginally posted by Winder Quote
Well, the metering sensor 'resolution' is 45x30 (3:2) segments - ie 1350 segments in a 45x30 matrix, like so:
But in total there are 6750 data segments recorded by the chip: 4050 segments for the RGB (ie 3 X 1350 data segment blocks, one for each primary colour group) + 1350 segments for flash metering + another 1350 segments for slave flash metering.
So it's not just 'resolution' but [colour] depth too.
It's all a lot more than the old 77 (7x11 matrix) segments of the K-5, 645D, K-S2 etc meter:
10-17-2016, 02:27 PM   #38
But the K-1 area actually is not fully centered, as you suggest with the red grid.
It is shifted towards the upper end.
Look at the Excel metering image and the roof of the shack in the top right corner.
Did you check my speculation on the colors and do you know in which order they are captured (if) in the metadata?
10-17-2016, 02:34 PM   #39
QuoteOriginally posted by beholder3 Quote
It seems to be green/yellow, blue, then red, as one can see here:
10-17-2016, 02:40 PM   #40
Thanks, that is quite interesting.
And there are still so many fields in metadata which nobody has decoded yet.
10-17-2016, 09:03 PM   #41
That's interesting and weird. Who knows. It's going to be hard to pin down. Time will tell I guess.
10-17-2016, 10:13 PM   #42
Digitalis's Avatar
Interesting data you have uncovered there Rawr, is there any indication of there being a UV/IR blocking filter covering the metering sensor? the Red channel data seems to be abnormally saturated. Though this could also be contributed to a mismatch between the primary sensor CFA and the metering sensor CFA.
10-18-2016, 12:08 AM   #43
From the hardware images of the sensor that I've seen, it's difficult to say. I don't think there is any such filter though.
In the hardware cutaways of the K-1 where you can see the RGB sensor, all I can discern is a small condenser lens in front of the sensor.
But it is hard to to be conclusive about what's in front of the RGB sensor without a more detailed image, and some information about the optical properties of whatever may be in front of the RGB sensor, and how that light is subsequently processed.
However it does not seem customary with other brand's to put an IR filter in front of their RGB sensors. I haven't seen mention of it in Nikon or Canon, for example. Canon even makes a special point about the RGB sensor of the 5D IV being sensitive to IR. So it is probably useful for the metering system to be aware [to a degree] of IR wavelengths.
10-18-2016, 01:11 AM   #44
Digitalis's Avatar
The reason why I brought up the issue of IR sensitivity in the metering system is due to the fact that IR focuses differently than visible light- it also predisposes the metering system to inaccuracies as CMOS sensors are particularly sensitive to it. And according to Pentax: on the K1, the AE system has has input on the AF system there may be some fine tuning to cancel out any discrepancy in spectral sensitivity between the sensors being used.
10-18-2016, 03:55 AM   #45
Canon mentions the IR capabilities of the metering sensor in many of it's newer cameras (like the 5DIV, 7DII and even eg the 80D) in terms of the contribution IR can generally make to more accurate exposure, perhaps including light source flicker detection, and maybe skin tone metering too.
Skin tone is important obviously for general shooting and portraiture, but is extra important for face detection to work reliably via a limited resolution sensor like a RGB sensor. Since some of those Canon's can do face detection AF via optical viewfinder shooting (like some Nikon's can), perhaps the problems of working with IR vs visible light can be compensated for, and balanced out by the ability of IR to help the camera meter find face targets.??
af, camera, cameras, conditions, dslr, event, flash, focus, full frame, full-frame, k-1, k-3, k1, lens, lenses, light, lights, pentax, pentax k-1, people, pm, shop, shot, wedding
Quality Control issues with K1 tomO2013 Pentax K-1 107 02-24-2017 11:41 PM
People Some wedding shots from the K1 tomO2013 Post Your Photos! 4 07-26-2016 12:28 PM
K1 Wedding Photography Impressions walro Pentax K-1 21 06-03-2016 12:41 PM
Shooting at a wedding. LeDave Photographic Industry and Professionals 12 09-28-2015 01:44 AM
All times are GMT -7. The time now is 06:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
