Hello, sorry if this is a repost but I can't seem to find the original...
In preparation for next week's photography class, the instructor suggested I pull out the Flash so we could discuss a few settings. He was a bit confused about the P-TTL setup over exposing the images. He's not familiar with the Pentax setup so I promised to try to do my homework. Here are my questions:
1. Also, even in P-TTL mode, when shooting the camera in manual mode, photos just seem to come out over exposed. This is particularly true with my 50-135mm. I can over come this via manual settings but P-TTL should work! Any thoughts.
2. AWB on my K-1. What setting do you folks use for your WB while using the flash. Neither one of us could figure out which setting was the appropriate one based on the documentation. The following is the online info I found:
The Pentax K-1's white balance system offers a wide range of options, including an interesting Multi Auto WB mode which aims to neutralize color casts from multiple different light sources in the same scene. As well as Automatic and Manual modes, the K-1 provides nine white balance presets (Daylight, Shade, Cloudy, Daylight Color Fluorescent, Daylight White Fluorescent, Cool White Fluorescent, Warm White Fluorescent, Tungsten, and Color Temperature Enhancement). This last option is used to retain and enhance the lighting tone - for example, to enhance a sunset.
White balance can also be measured from a neutral target, or a specific color temperature can be dialed in manually, using either Kelvin or Mired values. Three custom white balance values of each type can be stored in-camera. And finally, you can adjust white balance within a +/- 7-step range on both amber-blue and green-magenta axes.
I was able to adjust the white balance post processing but I really should know what setting to use when using the flash.
Again, sorry if this is a repost for the most part but I can't for the life of me find my other post.
Again, thanks for the all the help!
Regards,
Rodney
