Originally posted by lithedreamer U1 - Astro
B + IR remote, minimum ISO
Astrotracer and GPS on
Careful with that, I created such a custom mode, but Astrotracer would not activate even though everything was set properly. It worked as a bulb mode for me, whatever I tried. Better to just switch to bulb and use the INFO button (that one is a marvel!!!) to set everything for astro.
Originally posted by lithedreamer What have you guys set your custom user modes to on your K-1s?
I notice a lot of the user modes you think about sing can be easily set by using INFO and switching one setting (you are aware that you can customize the INFO menu, right?). I humbly recommend using user modes for scenarios where multiple settings must be changed. For instance, I have a "sports" mode where I use continuous shooting (with different priorities than regular), continuous AF, a higher ISO value, and different AF patterns. I have another for the studio, with all my go-to settings pre-programmed. another is set to force the camera to use APS-C lenses in FF mode (for the DA40 in particular).
Just my two cents, and congratulations on your purchase!
