Originally posted by RGlasel Nothing manufactured is 100% identical from one copy to the next, but it more likely that this "good" copy is slightly out of spec in a way that works better with your camera than the first three you tried. The odds of getting three copies with the same fault over a two year period, when your problem seems to be rare, are too small to be worth considering. I would be very interested to hear what Japan discovers about your second copy.
You did understand that I also have had three different camera bodies aswell? Not one body with three lenses but three bodies and each have been together with two of the lenses.
It is not unheard of that a whole batch has been "infected" with a problem. The DFA*70-200 I tested the other week was sold in Japan.
My DA*16-50 had a strange fault that led to the discovery of a problem that made Pentax re-program hundreds of those lenses in Europe.
So, yes I expect someone else to also have the problem. The same way that I was not the only one with having lost connection between K-1 and DFA150-450 and DFA*70-200. But very rare.
Well, yes I am curious on what the results in Japan will say.
