11-16-2016, 10:45 AM   #1
Battery & Astro Trace question
Has anyone had success with the astro tracer??? I tried once, no luck, share your pics if can.
Battery question... I'm wanting to get also into star trail photography... I assume the standard K-1 battery is not good enough to shoot for hours with lots of long exposures... Can anyone recommend me either an external battery or maybe a battery grip is good enough?
THANKS!!!
11-16-2016, 11:04 AM   #2
Star trails and battery: One hour of continuous 30-second exposures make a very nice photo when combined. I think you can get that from the standard K-1 battery.
11-16-2016, 12:50 PM   #3
Do you know if you turned it on correctly? The first night I went out with it, I ended up just taking long exposures because I turned the astrotracer on, turned the exposure mode to bulb, did a precise calibration, but didn't turn the GPS on.
11-16-2016, 01:06 PM   #4
Unregistered User
Guest
I recommend searching the forum for the astrotracer, O-GPS1, threads and read up on how this thing works. It is not just plug and play, you will need to know the limitations and the basics around the function.
11-16-2016, 03:25 PM - 1 Like   #5
Astro tracer, works great on exposures where you are attempting to capture a static image, example Milky Way. Here you want no movement i.e star trails as the trails will blur the shot and the Milky Way itself will blur with just a normal exposure much past 25 seconds. Astro tracer will allow much longer exposures, up to 5 minutes, brining in a lot of more light on distance astro features. On average I will expose in the 1.5 to 2.5 minute range. Note, that with a wide rectilinear lens, (like the 15-30), the edges of the image will still blur (or trail) since astro tracer can't accommodate the wider lenses. So keep the feature of your shot as centered as possible if you are using a wide lens.
Astro tracer, to me, is one of the main reasons I moved from Nikon (D810/D750) to the K1, as I can expose night shots at a much lower ISO, thus less noise and more details. Overall an excellent feature, when combined with the GPS.
Make sure you have a green signal on the GPS, and I always go ahead and re-calibrate the GPS if I move more than 15 feet. If your image is still showing movement in the center at 1 to 2 minutes then you should consider re-calibrating the GPS.
For star trails, you really don't want astro tracer, as it will defeat them.
For star trails, I would recommend you stack multiple exposures, instead of one long exposure. Stacking will allow you to pull in a lot more of the fainter stars and give you a better over image especially if you work with partial moonlight to help illuminate your foreground (something I always do).
Here is a short article I wrote several years ago, but it can give you some ideas on setup/capture and post processing on the star trail type of photography.
So far I have gotten about 1.5 hours on a single K1 battery, which is not quite long enough for a good star trails session, so I will use the grip with another K1 battery. The grip with AA NiMh, does not perform well at all. The K1 does not see the batteries with a full charge and only gives you around 30 minutes before you get a low battery warning, whereas with another K1 battery, you can easily get 3 hours.
You will need to use a intervalometer to stack. The K1 has a intervalometer, but I am not sure it if allows a timer function, (most DSLR's will only go to 30 seconds max with an internal intervalometer. There as many 3rd party ones on the market, that plug into the mic port on the K1.
09/23/14 Using Stacking for better Night Photography results @ Photos Of Arkansas
Paul Caldwell
Here is a vertical shot from late summer and you can see slight movement towards the top of the frame, again since I used a 15mm lens. Illumination done with a lantern.
[IMG][/IMG]
11-16-2016, 03:33 PM   #6
MJKoski's Avatar
Last weekend I took 150x 30sec exposures for star trails and the battery lost about 25% of charge. Temperature was -21C. I think this is rathe good.
11-16-2016, 03:54 PM   #7
QuoteOriginally posted by MJKoski Quote
Yes that is good. I tend to run 1.5 min to 2 minute stacks when possible and that seems to take a bit more out the battery.
Paul Caldwell
11-16-2016, 04:03 PM   #8
QuoteOriginally posted by adamwv Quote
THANKS!!!
Just write 'Astrotracer' in the 'Search the Forums' field and you will find lots of successes - plus a number of more or less comon issues too.
Some of my own humble achievements here: DSLR Astophotography: Astrotracer Images with Pentax GPS Unit O-GPS1
11-17-2016, 07:32 AM   #9
Thanks everyone!
08-22-2018, 02:11 AM   #10
I work with 3 accus.
08-22-2018, 02:30 AM   #11
Seeker of Knowledge
aslyfox's Avatar
THANKS!!!
I wonder if the OP has read this article
Pentax Astrotracer Guide and GPS Feature Comparison
A look at the O-GPS1 versus in-camera GPS
By K David in Articles and Tips on May 10, 2018
Read more at: Pentax Astrotracer Guide and GPS Feature Comparison - Articles and Tips | PentaxForums.com
or the in depth review of the O-GPS1
Pentax O-GPS1 GPS Unit
Introduction
The Pentax O-GPS1 unit is a small accessory unit that attaches to any K-01, K-5, K-r or 645D (or newer) camera flash hotshoe and provides geotagging of images (latitude, longitude, elevation), an electronic compass, and a simple navigator function. The GPS function also has the option of keeping the camera clock up-to-date. It was announced in June, 2011 and made available shortly thereafter.
Read more at: https://www.pentaxforums.com/reviews/pentax-o-gps1-gps-unit/introduction.htm...#ixzz5OtjdOQpK
or the user reviews:
https://www.pentaxforums.com/accessoryreviews/pentax-o-gps1.html
astro, astro trace, battery, battery & astro, dslr, full frame, full-frame, k-1, k1, pentax k-1
astro photography question hadi Photographic Technique 11 08-03-2016 10:33 AM
Astro tracer and wifi question. Gimbal Pentax K-1 & K-1 II 6 05-19-2016 10:18 AM
Forum newbie, K-3ii astro question Lucky IL Welcomes and Introductions 5 09-23-2015 06:45 AM
tracé JulieB Monthly Photo Contests 3 07-04-2015 08:05 PM
Astro Tracer (OGPS1) question LukeOB Photographic Technique 4 01-13-2013 05:30 PM
All times are GMT -7. The time now is 09:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
