Originally posted by 6x7II The thickness is not that important as long as the screen is pressed upwards in the direction of the prism, the top of the screen is the place were it should be sharp, thicker or thinner is compensated by the springs in the screen frame.
Unless something has changed with the K-1, thickness is a concern. On all SLRs, the intended focus plane is at the flat
underside of the screen facing the mirror. On the K-3 and all other APS-C Pentax dSLRs, spring tension via the retention frame is applied from that side of the screen upwards. Shims may be inserted between the screen and the bottom face of the pentaprism* to allow for variation of mirror box tolerance and screen thickness. When properly shimmed, the flange focal distance to the face of the focus screen will be identical to that of the sensor.**
I am pretty sure I am not blowing smoke on this matter. On the shelf in the other room is a box having an assortment of original Pentax factory part shims appropriate for current model APS-C dSLR cameras. I offer them for sale to people needing shims. They come in about ten different thickness. I bought them from KatzEye after they went out of business. KatzEye used them internally for their custom shimming service and would also sell them directly to Pentax owners of KatzEye screens. Similarly, focusingscreen.com provides plastic shims as part of the kit that comes with all screens they sell. Their screens are various thicknesses and each brand camera has somewhat different requirements. Most (all?) current brand dSLR cameras have similar means to adjust with shims and focusingscreen.com provides helpful instructions on both placing shims and adjusting for both front and back focus of the focus screen.
So...to repeat the question, how is the focus calibration with your replacement screen? Do you have good agreement with magnified live view and/or CDAF or is there indication that adjustment is needed.
* The bottom face of the pentaprism is fixed into a static indent in the chassis.
** It is the total height of the stack; screen, shim retainer, plus shim, that determines the location of the intended focus plane. Note that registration of the focus screen to the shim retainer is fairly critical on the APS-C cameras.
