Originally posted by DimC I've done some more testing, it seems that 1st Frame set to Focus priority then all subsequent set to FPS prioirty is quiet good.
Ill try AF hold to off, thanks.
Yes. The factory default "AUTO" needs to be removed. Its basically worthless. I'm sure most of the people doing on-line reviews are leaving the camera set to "AUTO" under the AF modes.
I use back button AF-C 99% of the the time and once I got the setting worked out the AF performed much better.
They need to improve the AF point illumination.
