11-25-2016, 11:59 AM   #1
Wide astro FF zooms and primes - got your eye on anything?
I'm interested in going to the K-1 at some point primarily for night and astro and also a general landscape.
There's some lenses already out and due to be released that are FF.
Pentax 15-30 f2.8
Samyang 14 f2.8
Samyang 20 f1.8 << due to be released, sounds interesting
Samyang 24 f1.4
Irix 15 f2.4
Pentax 2017 prime(s)
What are your thoughts/experiences on these?
11-25-2016, 12:04 PM   #2
I want something weathersealed, so I've looked at the 15-30 and the Irix. The latter takes screw-in filters, which would be nice for regular landscapes, but I don't know if it's worth giving up the zoom range.
11-25-2016, 12:22 PM - 1 Like   #3
BigMackCam's Avatar
QuoteOriginally posted by lithedreamer Quote
For what it's worth, I have an older Konica Minolta 17-35 f/2.8-4 on my A-mount equipment. I tend to find I use that far more regularly than I use my DA15 on the K-3. It has made me think about getting a wide or ultra-wide zoom for my Pentax cameras. Having the zoom range really is so much more versatile (for me, at least).
11-25-2016, 12:27 PM   #4
QuoteOriginally posted by Conqueror Quote
Many are waiting for these and it'll be interesting what they are?
11-25-2016, 12:33 PM   #5
Obin Robinson's Avatar
Pentax 15-30 f2.8
Samyang 14 f2.8
Samyang 24 f1.4
Irix 15 f2.4
My thought is that I wouldn't get those over any of my Pentax 67 or Mamiya 645 lenses I bought for astro work. Astrophotography puts lenses through paces that landscape photography does not. Medium format glass works well. It's good enough to do serious research with.
obin
11-25-2016, 01:34 PM - 1 Like   #6
Tjompen1968's Avatar
QuoteOriginally posted by Obin Robinson Quote
obin
How about some explanation on your statement? Why etc... What do you know that the rest of us do not?
11-25-2016, 02:00 PM   #7
QuoteOriginally posted by Tjompen1968 Quote
The K-1 is only going to use the central part of the medium format glass. There is a lot less curvature there and the stars, even at the edges, remain quite sharp. There is also no vignetting of the image and often no chromatic aberration either. Stars remain as pinpoints. For example take a look at what Richard Crisp has done with medium format 6x7 lenses.
A Gallery of Widefield Images From Pentax 6x7 Camera Lens Adaptor System
Just for example look at the full resolution images done with a Pentax 67 300 f/4 ED.
Here's an image taken with a Pentax 6x7 75mm f/4.5.
Medium format glass works good for astrophotography. It's inexpensive compared to getting a full blown astrograph like a Pentax 75 SDHF or a Borg 77 EDII.
obin
11-25-2016, 02:41 PM   #8
The Samyang 14/2.8 is a good bargain. Sharp even wide open. Doesn't have objectionable coma distortion. Those 2 factors make it good for astro use. The protruding front element requirew a special adapter if you want to use filters for general landscape use.
11-25-2016, 02:43 PM   #9
A great result, for sure. But for those who don't know, astro is one field where you spend as much if not more time in post- processing than you do in acquiring the original frames. I can guarantee that those frames straight out of the camera were nowhere near as glorious as the final result.
11-25-2016, 04:26 PM   #10
QuoteOriginally posted by jbinpg Quote
Correct. Astrophotography requires post processing because the image you are trying to extract is often invisible to the human eye. You could peer through the largest telescope in the world and your eye won't see as much detail as a digital SLR with an inexpensive telescope. Even when peering at a bright planet you'll see more detail with a digital camera. The images from space telescopes such as Hubble, Kepler, and MOST are digitally manipulated as well.
With that being said astrophotography requires good optics in order to get a good result. That's why astrographs like the Vixen VSD exist.
obin
11-25-2016, 04:39 PM   #11
Ex Finn.'s Avatar
Good thing that my seeing conditions do not justify something like that, or I be in trouble!
11-25-2016, 07:30 PM   #12
QuoteOriginally posted by Ex Finn. Quote
Ditto. I've been eyeballing one for a while but I can't justify it living in light polluted areas. On the other hand anyone looking for an amazing astrograph should look at the Astro Tech AT65EDQ. It is an amazing piece of optics for the money.
obin
11-27-2016, 08:04 AM   #13
An interesting review of the Samyang 24mm
Rokinon 24mm f/1.4 ED AS UMC Review – Lonely Speck
11-27-2016, 09:57 AM   #14
Pentax 15-30 f2.8
Samyang 14 f2.8
Samyang 24 f1.4
Irix 15 f2.4
You forgot:
  • the already available Laowa 15mm F4 Macro
  • the currently being dispatched Laowa 12mm F2.8
  • the announced without date Irix 11mm F4
  • the old Sigma 20mm F1.8
  • the old Sigma 24mm F1.8
If you are whiny about coma you probably should should use a narrower FoV, as none of these lenses will be without some compromises.
11-28-2016, 02:24 PM   #15
MJKoski's Avatar
I tried out Pentax 67 75mm shift lens on my K-1 about a month ago and that was funny experience - I have not seen such bad IQ for years. f/16 was okayish with no shift and that was about it. No more medium fail lenses for me. Maybe modern 645 lenses are okay but these ancient ones are not.
astro, astro ff, dslr, f2.8, ff, full frame, full-frame, k-1, k1, pentax k-1, samyang
Anyone done much astro on the K-1 with FF lenses? (e.g. 15-30, 31) Conqueror Pentax K-1 14 10-09-2016 02:34 PM
Loss and Gain, Primes vs Zooms Joshua A Pentax SLR Lens Discussion 19 03-01-2016 12:39 AM
Equivalent of Pentax primes on Canon and Nikon FF systems dexmus Pentax SLR Lens Discussion 2 10-01-2010 11:16 PM
Questions on SDM/HSM/Wide-Angle Zooms/Primes Biro Pentax SLR Lens Discussion 4 12-02-2009 06:24 AM
All times are GMT -7. The time now is 09:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
