Originally posted by peterh337
I used to know a pro with Nikon gear and he showed me how he could set up several Nikon flashguns and the one on the camera would communicate with the others using data encoded on a series of low power flashes i.e. no radio. However he wasn't doing any studio work AFAIK; he used to travel on commissions and photograph people "doing things".
Pentax use exactly the same principle, Peter. Works very well indoors, you don't need to aim right at the receiver of the other flash because there's enough bounce off walls and ceilings for the signal to get through. Outside, the range is cut down by sunlight.
Its name is 'wireless mode'.
All the Pentax flashes that support it, and any Sigma or Metz or whatever speedlights have what is called P-TTL capability - watch for that term in their specs.
The one that goes on top of your K-1 will have to be capable of being a controller, not just a slave, BTW. Again, you look at the specs, and post a question here if it's ambiguous.
