Show Printable Version 10 Likes Search this Thread
12-19-2016, 08:28 AM   #16
DimC's Avatar
I'm among the ones who struggles with the lack of illuminated AF point, or at least to have the grid illuminated as soon as AF button is pressed (not only when the AF is achieved) would help me a lot.
I never had this issue with either my K20, K5 or K3, but now I sometimes have difficulties when shooting under low light especially.
12-19-2016, 08:39 AM - 1 Like   #17
QuoteOriginally posted by DimC Quote
You are aware of the fact that on the Pentax you can simply press the "AF mode" button on the left side of the mount with your left thumb and the red illumination stays on for as long you press it?
12-19-2016, 09:55 AM   #18
DimC's Avatar
QuoteOriginally posted by beholder3 Quote
What ??
AM I a fool ??
Man I am about 3 hours from my camera but I can't wait to see what you've got there...Thanks for that.
Still it would be easier to have same behaviour as K3 or K5, as long as you press the AF (back button in my case) the AF point illuminate.
12-19-2016, 03:29 PM   #19
DimC's Avatar
Thanks for helping a poor soul like me, I never heard of that feature !
It definitely help but at the same time it means it would be really easy to implement this on the AF button as well.
That's something I hope Pentax will add in a firmware update soon.
12-19-2016, 03:34 PM   #20
Have you added it to the product suggestions sub-forum? It's a good idea, but that's where Ricoh would be listening.
12-19-2016, 07:35 PM   #21
UncleVanya's Avatar
For those using it frequently - do you see a battery impact? Maybe that's why it is only via the explicit button push?
12-20-2016, 06:54 AM - 1 Like   #22
DimC's Avatar
QuoteOriginally posted by lithedreamer Quote
https://www.pentaxforums.com/forums/201-product-suggestions-feedback/336018-k...ml#post3857699
Good idea,
Just did.
12-24-2016, 04:00 PM   #23
Is the single AF point smaller on the K-1 than the K5II? I ask because I've read this criticism before, even from the not to be named, but whose initials are dpr. Yet, I never had a problem with the K5 in this regard (subtracting my own mistakes). The disappearing AF point could actually be cast as an advantage because its disappearance is another indicator of being in focus. I can understand somewhat it may be hampering if using select AF point. Still, one should pretty much know where they are in relation to the point to be focused on. I guess constant illumination might help a little bit, but really, is it that big a deal? How did photography ever make it this far without the help of modern, technological camera razzle dazzle.
There, now I sound like a grumpy, old man.
12-24-2016, 05:09 PM   #24
amoringello's Avatar
I couldn't see the impact on battery being significant, but constant illumination would certainly interfere with trying to see your subject when its dark. The lines glow so bright they tend to obscure the view. The old tiny red block popping up momentarily didn't seem so intrusive, yet it way very helpful.
Some in between would be nice, but for now hitting the button on the side of the camera when I need a quick assist works pretty well.
dslr, focus, full frame, full-frame, k-1, k1, mark, pentax k-1, shots
Can barely see focus point in K1 yozza Troubleshooting and Beginner Help 6 12-11-2016 05:53 PM
How to change to single point focus frogoutofwater Troubleshooting and Beginner Help 15 04-24-2016 08:00 PM
Quickest way to change ISO when using focus point timmijo Pentax K-30 & K-50 10 09-17-2014 04:57 AM
Can't change from Manual focus to Auto Focus kellyy17 Pentax K-r 11 03-06-2013 09:37 AM
Pentax 55mm 1.4 Point to Point Focus Speed MBT74 Pentax SLR Lens Discussion 22 10-16-2012 06:35 AM
All times are GMT -7. The time now is 08:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
