12-28-2016, 05:20 PM   #1
Question: K-1 - What White Balance to use with Strobes?
I'm coming from a K-50 that had a "Flash" White Balance mode that the K-1 seems to be lacking. Is there a "Flash" white balance mode hiding somewhere or a way to approximate it? I'm actually in a workshop right now and with the settings from the light meter (confirmed with multiple meters) the images are coming out way over exposed. Thoughts?
12-28-2016, 05:33 PM   #2
QuoteOriginally posted by CoreyC Quote
Smaller battery powered flash units typically see the color shift as you lower power. 5600K is what I use in studio, but if you are shooting RAW it doesn't matter. Over exposure though is a different issue. The over exposure has nothing to do with the White Balance setting. Either your ISO is too high or your aperture is to large assuming you are shooting a 1/200.
12-28-2016, 10:33 PM   #3
According to the manual, when using flash lights, set white balance to AWB.
12-28-2016, 11:51 PM   #4
clackers's Avatar
Nearly every flash is designed to replicate 'Daylight'. You can of course argue about the exact Kelvin of that.
12-29-2016, 01:11 AM   #5
Digitalis's Avatar
Correct, "Daylight" Is considered to replicate equatorial sunlight at noon: 5000K. However due to the power level used, kind of gasses and the pressures they are under flash tubes can deviate, sometimes by a considerable amount from this standard.
On most cameras setting AWB for flash typically fixes the WBV @ 5000K
12-29-2016, 01:12 AM   #6
thanks everyone. I searched the pdf version of the manual before praying but couldn't find where it said to use AWB. For the workshop I ended up using multi-AWB which seemed to be ok but still not as true as I remember my K50 with the white balance set to Flash being. Time to test i guess. Thanks again everyone.
12-29-2016, 02:15 AM   #7
dcBear78's Avatar
Are you shooting in JPG?
balance, dslr, full frame, full-frame, k-1, k1, mode, pentax k-1
what lenses should i bring to NY to use on K-1? shaolen Pentax SLR Lens Discussion 11 10-11-2016 03:48 PM
White Balance issue using strobes Katja Pentax K-5 42 01-19-2016 11:19 PM
K-7 How-to-do-the-white balance question Syb Pentax DSLR Discussion 31 06-26-2011 11:01 PM
Does K-x use Kelvin for white balance temp? Briana Pentax DSLR Discussion 3 04-08-2010 03:22 PM
K-x White-balance question planedriver Pentax DSLR Discussion 13 01-02-2010 10:38 AM
All times are GMT -7. The time now is 05:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
