Originally posted by pichur How is this possible? I don't understand how a blank picture can be saved like this. Please explain.
Imagine that you put a number to no light at all, 0 and extremely bright light, 100. Your camera exposes well if it stays between 40-60. If the scene is bright, you close the aperture, shorten the shutter speed, and visa versa for dark.
What happened is that the photo was exposed between 20-40. The sensor picked up enough difference in light levels and colors. In software, the exposure was adjusted so that it moved to 40-60.
A good sensor picks up detail outside of the normal exposure range that can be used in an instance like this.
There are actual numbers that describe these things, but for the sake of illustration.
