Originally posted by svassh M or Av mode only
No Auto ISO ie no metering
No IBIS
Consider that there is NO coupling between the lens and camera body and that the body is not able to control ANY feature on the lens. That being said, the general rules are as outlined below with some variance between different bodies:
- You may shoot in Av or M mode
- Metering is stop-down, meaning that the meter measures the amount of light with the lens stopped down. In Av mode this is continuous. In M mode, you must use the green button to take a meter reading and set the shutter speed.
- Auto ISO should still work in AV mode and is not possible in M mode*
- Unless turned off, IBIS is available, but requires manual entry of focal length
Note that there is some variability in behavior between different body models.
Originally posted by svassh Seems odd the adapter mounts inside the K mount but does not click into place and there is no "outer rim" on the adapter that locks the lens mount.
That is how the conventional Pentax M42 adapter works. It is supposed to click into place and should be removable by depressing the small spring at 10:00 on the mount. At least that is how it works with the genuine Pentax-brand adapter. Cheap third-party adapters are famous for poor fit, poor finish, and an alarming tendency to become stuck on the camera. Conventional wisdom is to remove the retention spring from the adapter to avoid this risk, even though doing so will result in the lens not being locked on to the body. There are also so-called flanged adapters that have an outer plate to engage the lock mechanism, but which do not allow infinity focus. (I know all of this is very complex.)
* For some models, if auto-ISO is enabled, the camera will default to TAv mode even though the dial says "M". When a lens without contacts on the mount is used, TAv mode defaults to Av, so what you get is Av with auto-ISO. Strange, eh?
