Originally posted by MJKoski Yesterday I got new K-1. I did freezer test before leaving for another winter photo trip. I left it in freezer for 4 hours, but only -22C. Battery was included so it was frozen as well as I fired it up and tried PS & sensor shift. It still worked and EXIF reported -21C temps for the test frames. Maybe there is certain trigger point where something gives when going towards -30C. Or tolerances are wild within the IBIS construction.
Yes, it could all be tolerances in the IBIS with some K-1's being more or less sensitive to being used so far outside their manufacturer-specifications.
But it might also be a function of thermal distortions in the IBIS platform if the camera is used in certain ways at very low temperatures. If one side of the IBIS platform is warm (e.g., sensor running LV, long-exposure, LCD panel active, etc.) and the other side is cold (e.g., including changing lenses at extreme low temperature), the differential expansion would induce a curve in the platform which might cause it to get stuck in the IBIS housing.
