01-20-2017, 01:22 AM   #106
QuoteOriginally posted by fromunderthebridge Quote
True. Then again sooner or later the camera temp will drop to match the ambient. Unless you use some sort of active heating or sleep with the gear, neither of which seem very appetizing or sustainable on a week long trek.
Haha, I'll sleep with my K-1 to keep it warm (if condensation didn't worry me). Fair, fair.
01-20-2017, 05:15 AM   #107
-21C is current on our regular freezer, easily goes deeper. -18C is the standard for frozen food.
01-20-2017, 05:31 AM   #108
Tan68's Avatar
I imagine you keep a little water with you so it won't freeze.
It's all about choosing the correct bed fellows :^)
If anyone does sleep with the camera, they should keep it covered. I think vapor from the body in a bag would be bad for the camera.
01-20-2017, 05:39 AM   #109
QuoteOriginally posted by Tan68 Quote
Water is melted on demand with a gas stove. But yeah if you sleep with the camera you should definately protect the camera from sweat etc :P.
01-20-2017, 07:11 AM   #110
MJKoski's Avatar
QuoteOriginally posted by leekil Quote
You have a -22C freezer???
Yes, indeed. It has option to go to -25C but at the cost of horrible electric bill.
01-26-2017, 08:34 PM - 1 Like   #111
Hi all,
Just got back from a work trip to the Canadian arctic. I normally use a point and shoot or m43 camera for work (it's not pro photography work), but I brought my K-1 this time due to the very low light at this time of year. The temperature was between -28 C to -32 C and I was outside for 4 to 5 hours between breaks for 6 days.
The only minor issue that happened was the mirror stayed up once during a shot. It returned to normal after removing and replacing the battery. The rest of the time everything worked as normal with no special precautions taken. I was very happy with the performance overall.
I have used my other camera (Olympus E-M5ii) in these temperatures all last winter with no particular issues, just short battery life. But in my experience anything below -30C and especially nearing -40 causes strange behavior with any electronics.
01-26-2017, 10:57 PM   #112
QuoteOriginally posted by JensE Quote
Huh, I guess it is. I assumed it was closer to 0 C.
01-27-2017, 04:18 AM   #113
MJKoski's Avatar
The coldest night this week peaked at -30C and camera was exposed to cold that day for 6 hours in total. No such problems as the 1st K-1 but one side effect was detected - the IBIS system made noise similar like coil whine which is fairly common today with certain video cards. Although not as loud.
battery, camera, clothing, dslr, failure at -28c, full frame, full-frame, gloves, hours, ibis, ibis failure, k-1, k-5, k1, light, mittens, pentax k-1, post, sensor, shift, summer, temperature, test, unit
About IBIS - Which company started IBIS in DSLR's ? Curiosity question. jpzk Pentax DSLR Discussion 30 06-13-2019 04:56 PM
White Balance Temp ? Storm Chaser Flashes, Lighting, and Studio 8 12-31-2015 03:05 PM
Failure trend: DA 18-135mm may not focus to infinity at certain focal lengths bwDraco Pentax SLR Lens Discussion 7 08-16-2015 12:25 PM
Nature Straw-necked Ibis RobG Post Your Photos! 2 06-01-2015 04:35 AM
Nature Ibis, Ibis, everywhere photolady95 Post Your Photos! 9 05-11-2011 08:38 AM
All times are GMT -7. The time now is 06:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
