Originally posted by BigMackCam Whilst I don't own a K-1, I use Lightroom for all of my cameras.
Thanks for your comprehensive description! So pixel size and final resulution is not important to consider? My gut told me with a higher resolution / smaller pixels i may have to adjust the sharpening parameters like radius etc. - I'll play with radius then anyway.
Your settings sound comparable. You seem to sharpen a bit less, which makes sense as you sharpen the tiff afterwards. I will try that workflow.
As camera calibration i have no choice, its set to "embedded". With the K-5 i had a choice - don't know why.
Originally posted by Michaelina2 subtract the Luminance adjustment number from 100 and enter that calculation into the AMOUNT slider's adjustment result box
Thank you. As i mostly shoot iso <= 400 i don't really need NR, this would imply i should may use a higher value for sharpening by default.
Originally posted by BigMackCam what about batch processing multiple images and getting them "in the ball-park" - do you start off with any kind of preset? I think that's what the OP is really asking
Yes, that's what i meant. I'm sitting in front of 900 shots from my holidays, of which i expect to delete 600, edit 30 in detail and leave the rest more or less untouched with a preset.
Originally posted by Tjompen1968 I have set a Camera RAW defaults with a base sharpening
Nice shot. So you indeed use a default sharpening? I don't quite understand what you mean.
Originally posted by Bengan I never use development presets.
So you sharpen every single image from scratch? Because without shaprening my raws look much worse than every phone snapshot
