Originally posted by lightbox Since the camera only takes one AF adjustment value per lens, how do you calibrate a zoom lens? Do you split the difference and use a middle focal length?
You can do that, but it may prove inadequate. Why per-lens fine adjustment is needed is not immediately obvious and a little paradoxical. While poor physical placement of the PDAF sensor may require application of a global bias, per-lens variation in PDAF accuracy has a different cause related to design and manufacturing tolerance. A well-centered prime with few optical aberrations and traditional (non-internal) focus will seldom require fine adjustment. Add centering defect, field curvature, astigmatism, or LaCA to the mix and fine adjustment is usually needed.* Complicate with internal focus or zoom and the adjustment required may be different according to distance and/or chosen focal length.
Owners of recent Sigma products have the option of purchasing the Sigma USB Dock which may be used to upgrade firmware and do multi-point AF fine adjustment. It has been awhile since I read the general instructions (actual steps vary somewhat by lens), but if IIRC, one must calibrate at 3 or 4 different distances and at 3 or 4 zoom settings per distance. Yes, it sounds tedious, but reports are that it works quite well.
* These produce an ambiguous image to the sensor that reduces precision and may bias accuracy.
