Originally posted by rickclick I'm having some issues with underexposure in manual mode. I hand meter, do a custom WB with an expo disk and adjust my exposure to get the histogram spike to the middle. My meter and the histogram agree but my images (mostly portraits) are about 2/3 stop under exposed. This causes me to have to manually open my lens from about f/10 to f/8. I have tried using the +/- to compensate but it does not have any effect on my exposure. I've been a pro for 46 years so I do have some idea what I'm doing. I've tried finding a number to Ricoh/Pentax to discuss the matter but have been unsuccessful in that effort. Other than that I love the camera.
If you are going through all of this trouble I would first ignore the histogram on the back of the camera and jump straight in finding out where the camera clips data, the reason why I say ignore the camera histogram is it only shows you the jpeg processed data and not the raw.
Most cameras will underexpose the raw data 1-2 stops below the maximum exposure the sensor can store. The best way to see this is to find a raw viewer that allow you to see the clipping point. Instead of going into great detail and not reinventing the wheel here is some very useful information.
Why Bother Shooting RAW If You Are Culling JPEGs?
and another
How to Use the Full Photographical Dynamic Range of Your Camera | FastRawViewer
Here I done a little test
So here what I had done is use the cameras meter and metered on middle grey and using the cameras histogram showed this to be the best exposure, I have a nice range with no clipping happening in my data. Now is this the best exposure ? and have I captured as much DR the raw file would allow
So what data did the raw file capture
So here is what data was collected in the raw file and where the highlights sit in that file, as you can see I am rather far from clipping any data with this exposure and if you look close I am over 1 stop from clipping the white patch. So do you think this was the best exposure for this scene?
Now I can see that for the very scene I can increase my exposure by
1 stop correction ( 1 and 1/3 stops) without clipping any data.
So here I increased the exposure time by
1 stop correction ( 1 and 1/3 stops)and this is what the image would look like on the histogram of the camera
Doesn't look very good as I have clipped a lot of the data one would need for this scene or have we ?
Here is what the raw file captured with that 1 stop increase in the exposure, I have very little clipping in the data with less that 5% in the green channel.
So here is a side by side comparison, one using the cameras meter that produced a very nice looking histogram to that of capturing as much DR the sensor can store
So you may ask why go through all of this trouble
Here is a close up of the shadows and you can see a decrease in the shot noise, this was done utilising as much of the scenes DR with that of what the raw file from the camera can store.
Just by optimising this we can see a 1 stop decrease in the noise found throughout the image.
So the question arises how are you going to implement this into your exposure management? I have run out of time as I should be getting other things done tonight but will continue this another day.
I hope this was helpful
ISF
