Originally posted by sorins So, all my knowledge about what an "Off" means for a function is completely upside-down OK, I'll try to live with this, now that I've noticed it! Sorry for my stubbornness and doubts about your explanations! Thank you all!
Well, the SR is never fully Off except when the camera is in standby mode. The image sensor is floating on a plate to allow motion compensation done by the SR servo function. When you set SR ON, the sensor is moved on its plate in order to compensate for camera motion. That consume battery power , that is why even when the SR is set to On, it is not running all the time but only before shooting. However, when you set SR OFF, the sensor still needs to be centered and fixed on its plate, that's done via activation of the coils that are also used by the SR mechanism, and that's the noise you hear when you use LV or , if you don't use LV, you hear the noise when the AE sensor is activated i.e before the shot. When you let the camera is standby, and press the shutter button that start the AE metering again, you hear the SR noise again, even if SR if set to Off because the image sensor is being fixed in the center of the frame. Try it out , see if it makes sense.
