Originally posted by sbh Sure, any raw processor will edit jpeg and tif files. But it won't give you accurate results when you use the wb slider compared to raw. True white balance is one of the advantages in raw over other formats. You'll see the difference if you edit the same photo both in raw and tif/jpeg side by side.
I don't understand why jpg is deemed to be bad. I believe if you tend to making the jpg cover a reasonable amount of the histogram that you can get a very useful output. To get jpg, some resolution is lost in the illumination. The spatial sampling is the same. WB can be a residual correction just well as the primary one. In neither case do we have a set of measurements of temperature etc that really represents reality. Temperature is variable across the scene as are all the other parameters. How accurate are the instruments which measure these? Then it is plugged into the header as if sacred.
Because of the terminology used for the parameters, we assume that there is a certain level of accuracy implied. Most of the parameters are cosmetic and how the slider was programmed for you to input.
A nice test would be to test 16 and 8 bit TIF output from ACR or PDCU. You will have to pixel peeping real hard to see major differences. Jpg has lossy compression thrown in so test the lossy and lossless in saving the TIF.
RONC
