Originally posted by sibyrnes Well, I just got my new DFA 50 Macro. Here is a slide shot at f8:
I think f8 is good. Even if f4 has more resolution, you are limited by the resolution of the slide itself, and that resolution is most likely lower than DFA 50mm on K-1. And I don't think the difference between f4 and f8 is
that big, on that lens. Probably meaningless once you factor in the slide resolution (unless one of those special super high resolution films was used)
The results look good, the peak of that mountain is sharp and detailed.
