Originally posted by southlander 36Mpx plus pixel shift on to I suspect is overkill for an image of a slide.
I believe that's inaccurate. Good, well preserved film should contain much more than 36 Mp of resolution. Not sure if this applies to slides, but FYI :
Originally posted by http://www.kenrockwell.com/tech/film-resolution.htm: 35mm film is 24 x 36mm, or 864 square millimeters.
Since the lie factor factor from digital cameras is about two, you'd need a digital camera of about 87 x 2 = 175 MP to see every last detail that makes onto film.
Quote: And any decent dslr will have more than enough dynamic range.
I think that would be true for any modern DSLR, certainly the K-30. Not sure how much brightness there is in those slide projectors.
Quote: Where you would rent one of these projector based systems?
I emailed the company I listed in my first post a few years ago. They said they had one unit for rent. $400/first week. Quite pricey for a $3400 unit. I most likely shouldn't need it for more than a week, though. Not sure if they will still do it. At this time, the slides are 6000 miles away so I would need to get them shipped here first before contemplating a rental.
Quote: Also what they don't mention with the 30 slide/minute claim is all the prep work beforehand to get slides more or less free of dust and then all the time afterwards cleaning up the image for all the dust you missed.
Yeah, I really have no idea about the prep work. Post processing is something that can be done much later, at one's own pace.
---------- Post added 02-13-17 at 12:43 AM ----------
Originally posted by lithedreamer My film scanner has ICE removal for colour film, if this scanner does too, that can save a lot of time. I'm in the 'more resolution the better' camp when it comes to archiving film, but there's room to differ.
The Slidesnap isn't a film scanner, it's a device that will automate the shooting of slides with a DSLR.
I would think that any ICE removal for colour film could be done in software on the computer, as opposed to in-scanner/camera.
Is it really done in hardware on your scanner ? If so, that may be why the scans reportedly take forever with so many slide scanners.
Seems like it would be easier to just shoot the slides in RAW and then apply ICE in the computer subsequently, in batch.
Not sure what format you would target once you go from the camera's RAW and apply digital ICE to preserve the full quality. Some sort of 16-bit TIFF with lossless compression ? Probably huge. Not sure what kind of compression RAW files use to begin with.
---------- Post added 02-13-17 at 01:04 AM ----------
Originally posted by Na Horuk Any specific reason its not suitable?
Resolution - 16MP is too low for slides.
Quote: Sure, something like K-3 or K-1 or even the new KP would give you higher resolution, but at a higher price point, too.
What is this new KP ? I would be renting the K-1 as well as the lens and AC adapter probably.
A one-week rental of the K-1, AC adapter and a D-FA 100mm lens would be a little over $200.
Quote: If you want a new camera and want to use it for this project, I'd imagine the K-1 would be perfect. PS, high resolution.. But even K-3 or KP would be more than adequate, unless the photos were taken with some sort of super high resolution film.
DFA 50mm or DFA 100mm would fit well. Figure out which one goes with your slide mechanism. Dunno if that automated slide thing you linked to in OP can work with Pixel shift, and I don't know what kind of requirements it has, but it seems fairly good. I think we had some threads about slide scanning before, so you might want to search for other user's methods. Renting is a good idea. Good luck!
The K-30 fits pretty much all my daily still shooting needs, so I don't really want to purchase a new camera, and certainly not spend $2000 on one. I just want the best results for scanning my family's slides. My father passed away and there won't be anymore slides to scan afterwards. No one else I know is shooting additional film/slides. This is why I want to rent both the slide projector and the camera.
Last january, when my K-30 was lost, I bought a refurb K-30 on ebay for $200. I have several reservations about the K-1 that I don't want to go into in this thread as it would quickly detract from the topic. My ideal next camera unfortunately does not exist, and may never be made by Pentax or anyone else. I am not sure when something suitable will appear without too many compromises, but in the meantime, I'll keep using my K-30. But I believe there are better cameras to use for slides and I may as well rent the best since a rental would be relatively inexpensive, probably much less than it will cost to ship the thousands of slides from France to California.
---------- Post added 02-13-17 at 01:20 AM ----------
Originally posted by stevebrot Thanks for the pointer. The price looks reasonable. But it looks like they are only offering 10MP quality per slide, ie. 3000 dpi. That seems rather low. When he was alive, I remember my father using slide scanner and manually scanning a few slides at closer to 9600 dpi with his Epson scanner, which she still has, but she doesn't have time to scan at all.
Quote: [*]One holds that the aim is to archive the full collection digitally at high resolution and fidelity with the originals being potentially discarded[*]Another suggests proof quality scans for catalog purposes with archival storage of the originals with the intent of pulling the original at a later date for high quality scans or wet prints as needed[*]A third strikes the middle ground with all slides being scanned as proofs, with additional high quality scans being done for the best images ASAP as a hedge against degradation with time
It would probably be the first one in my case.
