02-16-2017, 07:32 PM   #1
K-1 weight vs K-5 II
IR reports the K-1, with battery, weighs 35.8 oz while the K-5 II, with battery, comes in at 42.3 oz -- Does the K-5 II really weigh more than a K-1 ?!
For reference:
Pentax K-5 II Review
Pentax K-1 Review
02-16-2017, 07:39 PM - 1 Like   #2
monochrome's Avatar
QuoteOriginally posted by mee Quote
For reference:
Pentax K-1 Review
K-1 1010 gm w/ battery and SD cards.
K-5ll 740 gm w/ battery and SD card
Source: PentaxForums K-mount DSLRs Camera Reviews
02-16-2017, 07:40 PM - 1 Like   #3
c.a.m's Avatar
The Imaging Resource table of specifications indicates that the K-5 II includes the battery and the 'kit lens', while the K-1 includes battery only.
02-16-2017, 07:40 PM   #4
jatrax's Avatar
K-5II should be 26.1 oz. The IR review states the weight includes the kit lens.
02-16-2017, 07:41 PM   #5
mee
Thanks, guys. That makes much more sense!
02-16-2017, 07:57 PM   #6
kiwi_jono's Avatar
And its obvious when you hold a K-1 that its significantly heavier than the K-5. But thats not necessarily a bad thing as the K-1 feels great to hold.
02-16-2017, 08:04 PM - 1 Like   #7
mee
QuoteOriginally posted by kiwi_jono Quote
I just realized I have a large, accurate food scale.
As a result, I weighed my camera with the 16-50 and QR plate together. The total weight comes in really close to that of the K-1 and 28-105mm which isn't that bad imo. Nothing I'm not used to holding... especially since the K-1 seems to have a taller hand grip which would be excellent for bigger hands..
02-16-2017, 08:21 PM - 1 Like   #8
kiwi_jono's Avatar
Absolutely - the taller grip is great! Its not that much taller really but it makes a big difference to comfort / feel.
02-16-2017, 10:12 PM - 1 Like   #9
Comparing the K-1 with 28-105 to the K-5 with 16-50:
The K-1 and 28-105 feels much better balanced than the K-5 and 16-50. The K-5 has a lot of weight in the lens so it wants to torque the camera out of my hand, the 28-105 shifts weight backwards to the camera body. The K-1 combo is smaller, too.
Sharpness is much improved. Many more megapixels, no AA filter, and a sharper lens. For on screen display it doesn't matter, but I can crop more and print larger with the K-1.
In low light they are around equal. Yes, the 28-105 can't reach f2.8, but the larger newer sensor in the K-1 surpasses the K-5's already great low noise performance.
The only spot where the K-5 combo has an edge is I get a little wider field of view. 28mm to 24mm equivalent (16*1.5 = 24) doesn't look like a big difference but I miss that extra wideness.
02-16-2017, 10:18 PM - 1 Like   #10
Specs that I read were K-1, 2 lbs., and K-5IIS, 1.7 lbs. D-LI90 is the battery type used in both.
02-16-2017, 10:23 PM - 1 Like   #11
jatrax's Avatar
That was exactly my calculations as well. The k-3 plus 16-50 versus the k-1 & 28-105. The difference is that the grip on the k-1 is so much better that the k-1 is actually easier to hold than the k-5 or k-3. At least for my hands, where the k-3 was just too small to fit my pinkie on.
02-17-2017, 01:33 AM   #12
The K-1 is about 30% heavier, not counting lenses
02-17-2017, 06:10 AM   #13
mee
QuoteOriginally posted by DeadJohn Quote
I have similar thoughts too. Esp with the grip and the pinky in free air. I also will miss the lens going down to 24mm (or 16mm on crop) as I often shoot on the wide end. Hoping for a wide prime to be announced next week. Or maybe even a wider zoom (doubtful but still would like).
Really a 24-120 f/4 type lens would have been perfect focal length wise. But the 28-105 seems like it will do otherwise.
02-17-2017, 06:34 AM - 1 Like   #14
monochrome's Avatar
In my experience K-1 fits my hands much better than K-3 or K10D. I grip with both hands, left as a platform. The K-1 feels natural and I'm not really aware it is there, whereas with K-3 I always felt the awkwardness of gripping with three fingers. Consequently I can actually hold the K-1 longer without tiring than I could the K-3.
So far it doesn't seem to matter which lens. Even a K300/4 let's me balance comfortably with left hand under the focus ring. In this case additional mass and volume is a benefit.
02-17-2017, 06:42 AM - 2 Likes   #15
35.8 oz ... 42.3 oz
QuoteOriginally posted by C_Jones Quote
2 lbs
All these archaic and inconsistent (UK vs US vs ?) measures ...
Luckily Wikipedia is there to help me figure out what they all might mean in grams.
battery, dslr, full frame, full-frame, google, ii, k-1, k-1 weight vs, k-5, k1, oz, pentax, pentax k-1, review, vs, weight vs k-5
FF vs APS-C Mini-showdown: K-1 50mm vs K-5 30mm noser Pentax Full Frame 8 05-10-2016 07:54 PM
K-3 vs K-5 II write speed mee Pentax K-3 15 09-27-2015 11:36 PM
AF.C on K-5 II vs K-3 StigVidar Pentax DSLR Discussion 2 06-22-2015 09:57 AM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
All times are GMT -7. The time now is 01:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
