Originally posted by lesmore49 My question is....by using a ASP-C lens on the K-1.....do I still get full benefit of the 36 MP sensor .....or ?
Select FF mode. This will mean that APSC lenses fitted will take an image with the whole sensor, but will provide some vignetting. As I understand it the 21mm will vignette heavily. I believe the 40mm is FF compatible and I know the DA70 LTD is FF compatible as I use it on my K-1. The caveat though is the 70mm does vignette and some consider the edges are too soft. YMMV and all that stuff as I like how it works on the K-1:
Free Spirit | Larger view on black (arrows, F11, click on th? | Flickr FYI, I added to the vignetting in this image so this doesn't represent what the DA70/K-1 combo looks like in FF mode. Here's three more K-1/DA70 images:
Bluesy Rider | best viewed by clicking on the arrows in the ? | Flickr just click the right arrow to go to the images of the cyclists.
The recommendation to switch to FF should also mean that if the 21 has usable image area between the K-1 crop and the vignetting you could potentially gain more than 15Mpx with that lens. Give the square crop a go too as that might work with the 21mm too. The benefit of this camera is the choice is yours as to what framing you want to use; crop, square or FF.
Have a trawl through here too, there's probably some example photos of each lens:
https://www.pentaxforums.com/forums/54-pentax-lens-articles/31629-da-lenses-...ts-thread.html
Tas
