03-13-2017, 08:05 AM - 1 Like   #1
Speeding up the K1 !
I recently purchased the DFA* 70-200mm lens to pair with my K1, and apart from my aching arm, I'm very impressed with the glass. Seems like there's a lot of accuracy and control.
One thing I've not been so impressed with is the ability of the K1 to handle a high frame rate. When I take a number of photos it feels like there is a log-jam to process them, and some times it won't allow me to photograph for a second or two, which isn't ideal.
Can people please give me some advice on which functions I should turn off to enable maximum frame rate, and other considerations, such as SD mode etc. This is for concert photography, so quite poor light/high ISO
Cheers
03-13-2017, 08:18 AM - 1 Like   #2
bobbotron's Avatar
What kind of SD card are you using?
03-13-2017, 08:34 AM - 1 Like   #3
Otis Memorial Pentaxian
QuoteOriginally posted by Dericali Quote
If you haven't already, turn off in-camera lens correction.
03-13-2017, 08:37 AM - 2 Likes   #4
TER-OR's Avatar
Shoot RAW, so you're not processing to jpg - and yes, lens correction is processor heavy too.
When I set up the K5 years ago, I turned off all the highlight, lens corrections etc. and saved it as a User mode. That was fast. Eventually I moved away from jpgs.
03-13-2017, 08:52 AM - 3 Likes   #5
bobbotron's Avatar
QuoteOriginally posted by TER-OR Quote
The nice thing if you do like the built in JPG processor, is that you can shoot raw, then convert all the images to jpg at the end of the event in camera.
03-13-2017, 09:32 AM - 2 Likes   #6
QuoteOriginally posted by bobbotron Quote
This is great piece of advice. Thank you.
03-13-2017, 10:32 AM   #7
I'm using 2x 64gb SD cards with 90mbs (or thereabouts) write speed.
03-13-2017, 10:48 AM - 1 Like   #8
f22
Samsung Pro + SD ranked at the top for read/write performance. And they don't spontaneously combust, like their phones!
03-13-2017, 12:12 PM - 2 Likes   #9
On the K1, the bottleneck is writing the SD card once the buffer is full. Once the buffer is full, the wait time prevents to continue shooting. Usually, subjects aren't in interesting posture all the time. The trick is to figure a time frame where the subject is interesting to shoot. The workaround is to lower the average frame rate, while keeping the highest instant frame rate during the time frame of interest, for instance interrupting the burst every 3 or 4 shots, RAW. That works very well for me, this way I can even shoot sports with a K1 and without being bothered by a full buffer. I did not find JPEG would help much, once the buffer is full, whether it is full of RAWs or full of JPEG, the amount of data to clear is the same. Important is not to waste frames on boring composition (wasting a lot of frames is what people do with the D500).
03-13-2017, 12:37 PM   #10
Nuno Almeida's Avatar
If you can shoot in crop, do it, the k1 feels faster in crop, even square crop, anything you can do to reduce file size or workload of the camera helps, keep it simple for the camera.
Btw when when I say shoot in crop, I don't mean to waste the pixis available in the K1, but like if you are shooting something that you know you will eventually crop, crop it to begin with.
03-13-2017, 03:25 PM   #11
sbh
sbh's Avatar
There was a discussion about card speeds including some tests somewhere.
K3 & K3-ii memory card write speed - PentaxForums.com
03-13-2017, 03:30 PM   #12
What brand and model?
Worth noting, perhaps, that not all SD cards are what they claim to be ... Some measure their specifications very idiosyncratically, many cards are also simply counterfeit, particularly if bought online. Hence many a card may not perform as claimed.
Also did you format your cards in-camera? Remember that 64GB SD cards need to be formatted exFAT, vs FAT32 for 32 to 4GB GB cards. Formatting outside the camera (eg on a PC) can sometimes mess up the file system, which may compromise performance.
03-13-2017, 03:36 PM - 1 Like   #13
Paul the Sunman's Avatar
QuoteOriginally posted by Nuno Almeida Quote
If you can shoot in crop, do it, the k1 feels faster in crop, even square crop, ...
Is that true? I understood square crop actually saved the whole FF image, but just raised a flag respected by most software to only display the cropped square. APS-C crop on the other hand saves only the crop region and is noticeably faster.
03-14-2017, 02:15 AM   #14
QuoteOriginally posted by Paul the Sunman Quote
Maybe, I don't usually use square and could be wrong, easy enough to try it
03-14-2017, 03:49 AM   #15
Indeed, with the square crop the full 36MP RAW is saved (with the appropriate crop tags) - however the embedded JPEGs are cropped. I'm not sure if that's enough to make a (tiny) difference.
Software like Silkypix or Pentax DCU can extract the full (non-cropped) image from a square crop RAW. I couldn't find any way of doing the same in Lightroom, and I guess some other applications might even ignore the crop tags.
cards, crop, dslr, format, frame, full frame, full-frame, in-camera, k-1, k1, pentax k-1, rate, sd
Sports Speeding down the track farmerDavid Post Your Photos! 3 07-14-2016 01:11 PM
People Fast as a Speeding Bullet rwfarnell Post Your Photos! 7 05-18-2012 05:43 PM
Travel doube b speeding in the rain bubblesT Post Your Photos! 6 04-18-2010 12:51 AM
Top Victorian traffic cop caught speeding fractal General Talk 27 02-09-2010 11:31 AM
Some thoughts on speeding up AF nobbsie Pentax DSLR Discussion 0 01-05-2009 09:07 PM
All times are GMT -7. The time now is 09:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
