03-25-2017, 05:55 AM   #1
gerardbaron's Avatar
K-1 and Tamron 70-200mm AF adjustment
Yesderday I try to fine tune the AF the Tamron 70-200
-10 and the focus isn't perfect, I am off by 2 line, I was using the viewfinder.
Others lenses adjusted correctly.
Also when I mount the lens on the K-1, I do not get a perfect fit compare to my others lenses.
Is it the K-1 or the Tamron? The Tamron is 2 months old.
What do you suggest?
03-25-2017, 06:20 AM   #2
Scorpio71GR's Avatar
QuoteOriginally posted by gerardbaron Quote
I have the Tamron and the K-1. They work perfect together no adjustment needed. It is well known about quality issues with the Tamron. If you purchased it new I would send it back if you are within the return period. Otherwise you can send it to Tamron for adjustment. One member here sent their K-1 and Tamron 70-200 into Tamron and was happy with the results.
03-25-2017, 07:19 AM   #3
ramseybuckeye's Avatar
When I first got my 70-200 the contacts did not line up right, Iactually sent it back twice, the second time with my K-30. They did a good speedy job, paid for all the shipping and it works fine with the K-30 and my K-50. Tamron's service is excellent.
03-25-2017, 07:22 AM   #4
amodali's Avatar
Is the k1 firmware up to date? Try to downgrade at v1.30... and let me know
/amodali
03-25-2017, 08:40 AM   #5
Stavri's Avatar
The best solution will be to send the K1+ lens for adjustment...Otherwise just the lens for calibration
03-25-2017, 10:08 AM   #6
Send to Tamron, excellent service
03-25-2017, 01:46 PM   #7
amodali's Avatar
Check your firmware version, just one minute of your time...
/amodali
03-25-2017, 02:02 PM   #8
Thank for your help. Monday morning I will go to Tamron, 25 mn from home.
My firmware is 1.4
03-25-2017, 02:43 PM   #9
amodali's Avatar
My firmware is 1.4
Applying to my k-1 the last v1.40 I had the same issue, solved by downgrade to the v1.30... good luck
/amodali
03-25-2017, 03:35 PM   #10
Digitiser of Film
BigMackCam's Avatar
As others have indicated, it's not that uncommon for Tamron lenses (not just the 70-200) to be somewhat out of alignment straight from the factory. I've had two brand new 70-200 and one new 28-75 that needed re-alignment from my local Tamron service centre, and another 28-75 in Sony A-mount that needed mount replacement due to a tilting issue (causing the focal plane to be non-parallel to the sensor). I didn't keep the 70-200 lenses as I decided to go with the DA*60-250 (I shoot APS-C with Pentax), but both 28-75 lenses were quickly fixed by the service centre. Following service, they were perfect
03-26-2017, 02:24 AM   #11
PJPycroft
Guest
Just bought a new K1 last week..... Notice the firmware is 1.0 so would suggest that firmware to 1.30 for Tamron 7-200 f2.8 it is ????
Thanks
Paul
03-26-2017, 02:49 AM   #12
amodali's Avatar
About AF fine tuning I had problem using the last firmware 1.4, think before you upgrade.
This is not related to the "not perfect fit" problem reported in the first post, of course
/amodali
03-26-2017, 08:22 AM   #13
I'm running firmware 1.4 on my K-1 with no issues.
03-26-2017, 08:55 AM   #14
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by amodali Quote
/amodali
I have no problems with 1.4.
03-26-2017, 12:40 PM   #15
kooks's Avatar
I use Tamron 70-200 and the 1.40 firmware and it all works great.. Actually it is one of my favorite lenses with the K1
af, dslr, full frame, full-frame, k-1, k-1 and tamron, k1, lenses, pentax k-1, tamron, tamron 70-200mm af
D FA* 70-200mm F2.8 In-Depth Review (and Tamron 70-200mm comparison) Adam Pentax SLR Lens Discussion 4 11-09-2016 06:22 AM
All lens needs AF fine adjustment, does the camera need a global adjustment? Thanks bennyxyz Troubleshooting and Beginner Help 9 04-21-2016 12:36 PM
Tamron AF 70-300mm or Sigma Lens 70-300mm or Sigma 70-200mm Ben Hunt Pentax SLR Lens Discussion 21 11-05-2008 05:47 AM
All times are GMT -7. The time now is 07:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
