05-03-2017, 12:06 PM   #1
TTQ225's Avatar
K-1 and Metz 58-2 in fill flash mode?
Hello, I wonder what is the preferred way to use this flash as a fill-in in a situations like illuminating a backlit face of the person outdoors? There are 23 ways to manipulate the exposure: a) to reduce flash output to -2EV in the flash itself, b) set up flash output in camera's menu to -2EV and c) set K-1 exposure compensation to -3EV, but which one is the best to produce the desired result? Both flash and K-1 have the latest firmware installed. Thanks.
05-04-2017, 06:36 AM - 1 Like   #2
mcgregni's Avatar
I wouldn't be setting minus 2 flash compensation, that's not likely to light much. If you're using an auto-exposure mode on the camera (and for me that means Av as the only really intuitive one for flash work) , then the cameras exposure metering is already programmed to try and ' fill in' your backlit subject ....it will attempt to create a balance between the ambient and flash exposures. In fact, you are more likely to need plus flash compensation if the backlight is strong, and also if your subject fills a lot of the frame.
Give your camera and flash the best chance by avoiding auto-ISO and set a sensible ISO for the situation ....for portraits at a distance of around 3-7 meters then ISO 200 through to 800 is likely to be 'sensible'. It may depend on the limitation of the max Sync speed (1/200thsec), which may push your ISO down in bright light, or your aperture may need to close down ......otherwise you end up in High Speed Sync terrain , but best to keep things simple firstly!
Start out with a test shot, and try minus 0.5 stop on the camera exposure compensation and plus 1stop on the flash compensation to start with.....see how it looks and adjust each as needed.
05-10-2017, 04:19 PM   #3
TTQ225's Avatar
QuoteOriginally posted by mcgregni Quote
Thank you for your advice. Unfortunately, the link you provided is no longer valid.
05-10-2017, 05:34 PM - 1 Like   #4
clackers's Avatar
HI TTQ25,
You can use either the camera dial or the flash's controls (no difference) to set the Flash Exposure Compensation to -1eV for an overall fill or -2eV to let some darker shadows remain and just some catchlight in the eyes.
dslr, exposure, fill flash, flash, full frame, full-frame, k-1, k-1 and metz, k1, output, pentax k-1
Cactus V6 II with Pentax K3, Pentax K1 + Metz 58 AF-2, Metz 52 AF-1 eriksvec Flashes, Lighting, and Studio 3 02-17-2017 02:38 AM
Warning! Read before installing new metz firmware for 58 af-1 and 58 af-2 Howdy Flashes, Lighting, and Studio 26 08-11-2013 09:27 AM
K5 and Metz 58 non consistant exposure in slave mode digitaddict Troubleshooting and Beginner Help 2 10-30-2012 11:14 AM
Pentax K20D and Metz 58 AF (HSS Mode) jasper Flashes, Lighting, and Studio 7 01-22-2009 02:41 PM
All times are GMT -7. The time now is 02:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
