Originally posted by wings Thanks for that information. That is a relief. The reason that I am interested in this feature is that I will also be using the K-1 with a unit that controls the shutter while moving the camera and many of the on-board programs use long exposure times such as 100 sec intervals. I assume then that this would function the same as the Timer Remote Shutter Cords would.
As long as there is a cable running from the control unit that is used to remotely trip the shutter, it shouldn't be a problem. My mount for my telescope has something similar, a cable release output - as it happens it is a 2.5mm mini jack (designed principally for Canon, and 2.5mm plugs are dirt cheap, it just happens to be that the K-1 uses the same cable jack), though there are adapters available for other makes. The mount's hand controller can than be programmed to trip the shutter - I don't actually use this feature as I prefer to use the intervalometer I liked before, but the idea is the same.
