05-13-2017, 08:42 AM   #1
micromacro's Avatar
I need HSS flash for K-1
I know it have been a few threads about flash for K-1, but I have kind of narrowed question.
I need the flash with HSS function with K-1 on camera, not off. Yes, for shooting at bright day light at high speed and wide open, or near wide open aperture. .
What the best option considering performance, power, and reliability can be?
I'm thinking about Pentax newer generations, either 360II, or 540II, but what about the generation before it?
05-13-2017, 08:47 AM   #2
Should work as well I believe.
I have a Metz 58AF-1 and it has HSS.
05-13-2017, 09:00 AM   #3
micromacro's Avatar
QuoteOriginally posted by felixkh Quote
My cheap Bolt VS-510P has HSS button, at in theory should work with K-1, but it does not work with K-1 no matter how I've tried.
05-13-2017, 10:09 AM   #4
QuoteOriginally posted by micromacro Quote
Certainly the 360 FGZ, 540 FGZ and 360II, or 540II will deliver HSS on the K-1. I own the 540 FGZ. For your stated application, don't scrimp on flash output. Even for outdoor fill, HSS severely limits range. Anything over about 6 feet gets pretty dicey at high shutter speeds even with the 540.
05-13-2017, 11:09 AM   #5
I am selling a pentax and Metz flash on the for sale board.
05-13-2017, 11:45 AM   #6
mcgregni's Avatar
Yes, I second that, you really need all the power you can get for HSS.
The older and newer versions of the Pentax AF-540 FGZ flashes are essentially the same, and perform the same for HSS operation. It will come down to budget, whether you want the power-pack option or the WR, the LED light etc.
There's a full run-down of all the differences plus full coverage of the controls and interfaces in my 'Pentax Flash Guide' .....download the PDF from the link below my post here.
05-13-2017, 12:01 PM   #7
Selling the external battery pack and the Flash in the marketplace
05-13-2017, 12:35 PM   #8
LeRolls's Avatar
QuoteOriginally posted by mcgregni Quote
This is true. I have both generations of the 540 and have used them extensively for HSS for both the K-1 and the K-3. I prefer version 2 of the 540 because of it's WR and smaller size but I keep version 1 with me as a backup.
05-13-2017, 12:52 PM   #9
micromacro's Avatar
QuoteOriginally posted by Korg Quote
Yes, I checked all the available sales on marketplace. Need to learn a bit more to decide.
---------- Post added 05-13-17 at 12:55 PM ----------
Thanks, I took a brief look on your guide, and will read it later on.
---------- Post added 05-13-17 at 01:02 PM ----------
QuoteOriginally posted by LeRolls Quote
I'm glad to hear from the master. I read that newer version does not have bounce card, but LED light instead. What do you prefer personally? I don't plan to make video, do I need that LED?
05-13-2017, 01:17 PM   #10
LeRolls's Avatar
I hardly use the LED light but it does occasionally come in handy. I also don't use a bounce card either since I have the lightsphere modifier. You mentioned using the flash as on camera. I would recommend a flash sync cord instead. The version from Vello is what I have and use.
05-13-2017, 05:13 PM   #11
mcgregni's Avatar
The LED as a catchlight has the advantage that it remains front-facing for all types of bounce use. The old style white panel is only useful when the flash head is pointed upwards, not sideways. I believe that often the nicest bounced light comes from sideways angles, and so the white panel is no use like that. The LED would be useful in that situation, although I should add that its effect is not particularly strong, it is a very subtle fill-in, and there's no way to control its strength.
I actually use the LED mostly as a focussing aid when shooting macro stuff with manual tubes and a stopped down manual lens. At F16 it can be impossible to see anything even in daylight, so I mount the flash and put the LED on while I focus .... that way I don't have to move at all and can focus precisely and shoot at the same time.
05-13-2017, 07:13 PM   #12
Class A's Avatar
Inexplicably, Pentax do not support the AF-assist light on the older generation, so if that feature is important to you then that rules the older ones out.
05-13-2017, 07:19 PM   #13
mcgregni's Avatar
Do we know exactly from which camera model the AF-Assist support on the older models disappeared ? My K7 is fine with it.
05-13-2017, 08:23 PM   #14
micromacro's Avatar
That means that you use flash off camera, right? (kind of stupid question, but to make sure)
---------- Post added 05-13-17 at 08:25 PM ----------
I have AF-assist light on Bolt, and found it very useful in very low light, basically in dark. I'd like to have that option with K-1 and Pentax flash.
05-13-2017, 08:50 PM   #15
mcgregni's Avatar
I think you would have that feature with the K1 and the newer 'MkII' versions of the Pentax flashes. I think ClassA earlier was referring to the removal of support for the AF 'spotbeam' on the previous flash models with newer DSLRs ..... I'm just not sure exactly which model this this first happened with.
Be aware that the AF assist beam on the 'MkII' flashes uses the LED light. .....this is a strong white light that will be very obvious and distracting in dark situations (however there is a custom function to set the brightness level to either 1/1 or 1/2) . This is different to the previous flashes which use a red 'cross hair' pattern, which is fairly unobtrusive.
camera, dslr, flash, full frame, full-frame, hss, hss flash, k-1, k1, light, metz flash, pentax, pentax and metz, pentax k-1, pm, version, wr
Starting to test Godox HSS with Cactus V6ii, HSS works in AV mode? jake14mw Flashes, Lighting, and Studio 6 04-13-2017 07:30 AM
Need a pair of flash triggers with HSS GraySaint Flashes, Lighting, and Studio 23 03-01-2017 01:19 PM
Short flash duration vs high speed shutter/HSS flash dfp771 Flashes, Lighting, and Studio 8 08-28-2016 02:13 PM
Acon R930 multi flash setup HSS fun fact using Metz-Canon flash as second unit beholder3 Flashes, Lighting, and Studio 4 03-29-2016 03:29 AM
Radio trigger for HSS I don't care about P-TTL just HSS. PTTL not neccesary or wanted MD Optofonik Pentax Camera and Field Accessories 11 05-04-2013 03:59 AM
All times are GMT -7. The time now is 06:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
