Originally posted by jlstrawman The use of WI-FI is fully explained on page 88 of the K-1 manual, including situations when WI-FI is disabled.
Could you expand on what you're referring to? Why do people need to be so difficult?
Two situations are listed; when USB is connected and when in Movie mode... and while powered off, of course.
Less text than explaining where to find it. I can see helping someone to research their own problems, but the reference is not at all helpful because it is quite obvious that the information does not even apply.
P88:
This camera has a built-in Wi-Fi function. By directly connecting to a communication device such as smartphones and tablets via wireless LAN, the camera can be operated from the communication device and images can be shared with others via social networks or e-mail.
Enabling the Wi-Fi Function
The Wi-Fi function is disabled when the camera is turned on. Enable the function using one of the following methods.
• Settingfromthemenus(p.89)
• SettingwiththeSmartFunction(p.89)
When the Wi-Fi function is enabled, the Wi-Fi lamp lights up and the 7 (white) icon indicating the wireless LAN status is displayed on the status screen and Live View screen. When 8 (gray) is displayed, a connection with the communication device is not established correctly.
t Memo
• Even after the Wi-Fi function is enabled, it returns to an inactive
state when the camera is turned off and on again. Also, when
the camera enters C mode, the Wi-Fi function is disabled.
• Auto Power Off is not available while a Wi-Fi connection is established or images are being transferred. If Auto Power Off is activated while a connection is not established or during standby, the Wi-Fi function is disabled. The function is enabled when the camera recovers from Auto Power Off.
• TheWi-Fif unction is disabled during the USB connection.
u Caution
• DonotattempttousetheWi-Fifunctioninalocationwhere
the use of wireless LAN devices is restricted or prohibited,
such as on airplanes.
• WhenusingtheWi-Fifunction,observelocallawsand
regulations governing radio communication.
• Ifamemorycardwithabuilt-inwirelessLANfunction(suchasan Eye-Fi card or a Flucard) is used, radio wave interference may occur. When this occurs, disable the Wi-Fi function of the camera.
