05-15-2017, 08:55 AM   #1
Exposure Preview?
Brothers the other day when I was using the K1 a star appeared (!) by the settings and I had the joys of an exposure preview. This is jolly useful with flash. Normally the K1 shows the exposure as it would be with the chosen settings, but when using flash, this preview is often too dark. Any ideas how to turn this on and off? Thank you!
Ben
05-15-2017, 09:08 AM   #2
photoptimist's Avatar
If you rotate the On-Off lever in the opposite direction from Off (toward what looks like a hexagonal aperture circle), it takes a preview image. There might be some menu settings that modulate what this does but if you saw one, then your setting are probably OK.
Or you might be talking about AE-L (Autoexposure Lock) which you get by pressing the AE-L button on the upper right of the back of the camera and which causes a star to appear.
24x36mm, exposure, flash, full-frame, k1, pentax, preview, settings
Liveview: Can't Disable Exposure Preview Doundounba Pentax K-1 14 10-24-2019 07:35 PM
over-"exposure" of LCD preview Sluggo Pentax K-01 12 09-03-2016 02:51 PM
K-S2 Live View Exposure Simulation/Preview anu l Pentax K-S1 & K-S2 7 12-08-2015 12:52 PM
Can I get onscreen exposure preview? MrSkelter Pentax K-01 50 03-27-2013 09:11 AM
How to make sense of the DOF preview/Optical preview on the on/off dial ? photoleet Pentax K-5 5 04-17-2012 04:22 AM
All times are GMT -7. The time now is 10:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
