Originally posted by wings
The Adobe link above resolved the problem, many thanks. The black mask disappeared and so far I have not encountered any problems. I have learned my lesson(s): Double check the file format, ie RAW and Never use the conversion tool in the Pentax utility.
I did run across something during my searches for this problem that may come in handy for a different problem. If you use Sandisk SD cards, they have a free utility that would allow the recovery of deleted files whether intentional or accidentally. Here is the link:
Free SanDisk Recovery Software Recovers Lost Sandisk Data - EaseUS SanDisk Recovery
Many thanks for all of your help.
During some years I have made use of RAW pictures from my Pentax digital cameras instead of JPGs. Until now I have always chosen DNG as my ordinary in-camera-format, and this has worked all right without any flaws whatsoever. Lately, with my new K-1 II in action, I have started to test the PEF format in order to see what "goodies" the improved pixel shift function actually offers me in some cases.
Initially I decided to open my PEFs in DCU and immediately save them as TIFs before taking them into LR 6 for my final editing and export as JPGs. However, TIFs get so very big on disk. I then decided to instead save my PEFs as DNGs by making use of DCU in order to ensure that the PS properties are handled and really transferred into the DNG format and do not get lost. Thus I lately imported such "DCU-DNGs" into LR 6 instead of TIFs to see if there was any short-coming that I had not foreseen.
The "DCU-DNGs" look very good and I cannot see that their quality is different from the "DCU-TIFs" when I compare the same pixel-shifted pictures saved in both formats to investigate this aspect. My problem is that in LR 6 I cannot read the PEFs from my K-1 II and will never do since there will be no more updated camera adaptions after LR 6.14 (I do not want to subscribe to LR Classic CC or LR CC). However, I hope that at least Adobe DNG converter will go on getting updated. Then I will be able to compare "PEF-to-DCU-DNGs" with "PEF-to-Adobe-DNGs" emanating also from my K-1 II to see the difference. Earlier small and simple tests with PEFs from my older Pentax houses indicate that the quality improvement with PS on is clearly visible and a positive gain worth some added effort but also that pictures taken with PS on get degenerated quality saved as in-camera-DNGs compared to what DNGs normally result in. Conclusion so far: only PEF-through-DCU processing takes care of the positive potential of more nice-looking pictures with PS. There are no direct alternatives so to speak!
As regards the lost upper 1/3 of the pictures, I did not see that phenomenum in the few PS pictures I tested so far. It seems that computers and computer programs AND camera brands and camera models are somewhat like different "personalities" which, not always foreseeable, end up in different outcomes so to speak! It is not always easy to be a photographer. Still, I find that the digital era does not only increase my technical problems but also my productivity and creativity in many ways.
