07-20-2017, 06:56 AM   #1
looking for replacement of pin cover on K-1 battery grip.
I don't really know where to post this, but since I'm looking for a K-1 part I thought I'd start here. After several days of intensive tripod usage (I always remove the battery grip when I'm using a tripod) I've lost the small white plastic cap that covers the i/o pin array on the battery grip. Since the cover protects the delicate pin array, I'd like to replace it but haven't found a source. I've tried Ricoh Imaging, Amazon, Adorama and B&H. It might help if I knew what it's official name is. If anyone can help I'd be grateful.
NaCl("little white plastic cover thingy" gives 0 results)H2O
07-20-2017, 07:04 AM   #2
c.a.m's Avatar
I am looking for the same item for my K-3 battery grip (D-BG5).
I think the proper name is 'battery grip terminal cover' or 'terminal cap'.
Here's a recent discussion: Replacement Battery Grip Contact Covers - PentaxForums.com
The only reference I have found to a related part (for the D-BG4) is at SRS in the UK: Pentax D-BG4 Battery Grip Terminal Cap - Pentax Accessories - Accessories (I don't think they ship to N. America).
I have had no luck finding a source, so I may fabricate a make-shift part myself.
- Craig
07-20-2017, 07:12 AM   #3
QuoteOriginally posted by c.a.m Quote
- Craig
I think you two are looking for something different. Sodium chloride is looking for the clear plastic thing that covers the grip pins when the grip isn't in use, while you are looking for the black rubber stopper that fits on the bottom of the camera when the grip isn't attached.
I called Ricoh about the black rubber plug and the guy mailed me out one free of charge, as it can't be purchased anywhere. I am not sure on the pin cover -- I'd probably call Pentax/Ricoh on that as well and see what they could figure out.
07-20-2017, 09:28 AM   #4
c.a.m's Avatar
I also need the "plastic thing" that covers the pins on the grip, not the "black rubber stopper" that covers the contacts on the camera.
I think we're both looking for the item that is illustrated at the SRS link. Apologies if my link to the earlier PF thread implied otherwise.
- Craig
07-20-2017, 02:24 PM   #5
8.99 though, there must be a lower cost than that
07-21-2017, 06:50 AM   #6
Can you provide the contact number for Pentax/Ricoh?
07-21-2017, 07:52 AM   #7
pete-tarmigan's Avatar
- Craig
The operator's manual calls it "interface pins cap".
07-21-2017, 08:14 AM   #8
QuoteOriginally posted by Bob 256 Quote
I am not sure. The Ricoh website doesn't seem to up at the moment. It used to be based in Denver.
07-21-2017, 08:32 PM   #9
If you're saying you found the telephone number on the Ricoh website - that works for me. Will check it out the next time it's up. If you get any more information, please post just in case. Thanks.
05-03-2018, 03:44 PM - 3 Likes   #10
Not a Number's Avatar
The Ricoh Imaging US customer service number is 1-800-234-0276
If they won't help you US Camera carries this part, it says for the K-3/ii, K-5/ii/iis and K-7. It wouldn't surprise me if it fits the K-1 too.
Pentax Bottom Cover Connector Cap 77240-A410 | USCamera parts+USCamera
10-11-2018, 09:20 AM   #11
blackcloudbrew's Avatar
Wow, USCamera came through with replacement terminal covers for my K-1. Thanks for the link. Couldn't find them anywhere.
04-07-2019, 09:38 AM   #12
QuoteOriginally posted by NaClH2O Quote
I found this cover when searching for vintage parts Pentax 77970-A0410 Connector Cap | USCamera Genuine Pentax PartsUSCamera
04-07-2019, 11:50 AM   #13
Mikesul's Avatar
Nice find. I suspect a few of us will need this sometime.
battery, cover, dslr, full frame, full-frame, grip, k-1, k-1 battery, k1, pentax k-1, pin, replacement of pin, tripod
K-3 rubber grip cover replacement dcpropilot Pentax K-3 11 05-23-2017 10:02 AM
Replacement PC sync port cover for ME Super tumblesophie Pentax Film SLR Discussion 6 10-03-2016 01:36 PM
Pentax SP500 battery cover replacement options 6BQ5 Pentax Film SLR Discussion 3 09-09-2013 05:15 PM
BG2 Battery Grip Pin Layout alexcam Pentax Camera and Field Accessories 11 01-17-2013 04:17 PM
How to cover the SDM contact pin? HermanLee Pentax SLR Lens Discussion 5 05-29-2009 01:11 PM
All times are GMT -7. The time now is 07:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
