---------- Post added 10-04-17 at 01:43 AM ----------
Originally posted by pschlute With the k1 and those lenses, on a tripod , use a shutter speed faster than 1/250 and you will be fine. or use LV ES, and you will be fine.
With the K1 and those lenses handheld , just amke sure to enable SR and you should be ok. I can use the 300 at 1/60 and get sharp results.
It is not an insurmountable problem.
OK - not always for my 28-105mm within the shutter speeds mentioned. Do not forget the main thread-subject, that very lens. I do not even use it any longer.
Otherwise - sounds like throwing away my 2.5kg tripod - hallelujah - by just using SR....
OK - I know what You say - and mostly do so - because I'm not always sitting under a camouflage-net going through the K1 preflight checklist fiddling with all possible MENU-settings.
However - the K3 gives me more keepers and is good enough for my Epson pro 3880 A2-prints and panoramas with a RIP-software. A perfect K1 would be better though.
K1 is slower taking care of all that "not to do things" and the preparations You suggest - making me uncomfortable. If I need more dynamic range my K5IIs helps me out a bit and Q-image helps me increase size.
Not to forget, when I'm lucky with all K1-settings right and the object/situation has not suddenly disappeared - the K1-ones are great.
I'm on the list for K1-SAS (Super-Anti-Shock) without a mechanical shutter but rather with an optical one. (Like a window switching black to transparent with an electrical impulse - They seems to be out there...soon to make entrance. Search the net. Possibly to expensive/imperfect for the the moment.)
