09-14-2017, 04:21 AM   #1
latest update: nothing works!
Hi, has anyone had the same problems trying to update the K1 with the latest updates?
I've followed the instructions and downloaded the zip file, I've tried both the SD card method as well as the cable to Mac method.
I turned on the camera while pressing the menu as ordered....nothing!
Heeelllppppp
PS very worried about the warnings from Pentax if it fails etc......
09-14-2017, 04:28 AM   #2
hmmmmm very concerning. I am yet to upgrade from the original firmware. Perhaps I wont
09-14-2017, 04:30 AM   #3
If you click on the folder it will extract a .bin file. it is about 18meg. Place that file in the root directory of the card. Then try the update again. I always use and older card just for firmware updates. The only file I have on the card is the bin file.
09-14-2017, 04:35 AM   #4
QuoteOriginally posted by gaweidert Quote
Thanks: Root directory? Is that the same as copy and pasting or dropping on the the SD card?
09-14-2017, 04:46 AM - 2 Likes   #5
severalsnakes's Avatar
Can you put the SD card in the computer and copy/paste the .bin file onto the card?
I always mess up by putting it in the DCIM folder, then I have to go back in and move it.
I try to remember every time and I forget every time. -_-
Anyway, I just updated and the camera works fine.
09-14-2017, 04:47 AM   #6
QuoteOriginally posted by Mark (MC) Quote
Yes. It must not be in any folder.
If you place the folder with the zipped file on it onto your SD card nothing will happen. If you open the folder and click on the file you will get a new file that is about 18 meg. It will have a .bin extension. That is the file that needs to be in the root directory. The file name is fwbc228b.bin.
As a heads up, the firmware update file will always be named fwbc228b.bin and it is easy to confuse them. For this reason I always save the downloaded folder as it has the firmware version as part of it's name.
09-14-2017, 04:50 AM   #7
boriscleto's Avatar
Also make sure you don't have another .bin file in the download folder. One time I unzipped the file and it got renamed because there was already a file with the same name in the folder...After fixing the file name it worked fine.
09-14-2017, 04:57 AM   #8
CypherOz's Avatar
Updated to 1.42 no issues
09-14-2017, 04:59 AM   #9
Tas
QuoteOriginally posted by Wild Mark Quote
Perhaps you should do the upgrade as there's nothing wrong with them and there's been quite a few improvements to the K-1 via the firmware.
09-14-2017, 05:26 AM   #10
pschlute's Avatar
Make sure you are putting the card in SLOT 1 !!!
09-14-2017, 07:55 AM   #11
jlstrawman's Avatar
Just do it. Takes less than 1 minute.
---------- Post added 09-14-2017 at 09:57 AM ----------
Yes. Outside the DCIM folder.
09-14-2017, 09:55 AM   #12
Heeelllppppp
If you follow the troubleshooting guide and/or video in this post, you should be good to go:
Pentax K-1 Firmware v1.42 Released - Firmware Updates | PentaxForums.com
09-14-2017, 01:49 PM   #13
Upgrade went smoothly as usual but I was certainly hoping for that video IBIS. Patience.......
09-14-2017, 05:18 PM   #14
Paul the Sunman's Avatar
Very quick, very simple, as always.
09-14-2017, 05:26 PM   #15
KDD
Not put it in DCIM I'. Put it on k-1.
dslr, full frame, full-frame, k-1, k1, method, pentax k-1
Cannot seem to download latest firmware update for my new Pentax K-S2 Novice John Troubleshooting and Beginner Help 5 10-13-2016 02:03 AM
Latest firmware update page whereabouts Nakedgun Pentax DSLR Discussion 2 11-06-2014 09:18 PM
Used Sigma 15 FE does nothing on my K5IIs but partially works on K10 & K20... primo Pentax SLR Lens Discussion 8 03-10-2013 02:36 PM
They learned nothing and forgot nothing jeffkrol General Talk 0 12-09-2012 10:24 AM
Pentax M Lens works on Kx? DA L lens works on Vivitar 2X Macro Teleconverter? Kenneth3aracing Pentax SLR Lens Discussion 6 05-06-2011 08:54 AM
All times are GMT -7. The time now is 08:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
