This quick day trip to Oak Creek Canyon and in particular the West Fork was to essentially re-acquaint myself with the surroundings - in particular, with the K1 and how the additional real-estate can be effectively used. I've shot a lot of wide angle in some off nominal situations which have turned out pretty well.
- Overall with the DA 12-24 I was extremely happy with and shot quite a few of my most favorite shots. But I asked and was granted the opportunity to shoot the USS Constitution at sunrise and sunset a few years ago and with a bit of math - determined that the 12-24 was not going to do it. So, I picked up the 8-16 so with a limited amount of space to work in (in a ship yard) was able to shoot a large square rigged sailing ship from waterline to the top of the main mast in a single frame (she moves a bit with the tide and breeze). I was also able to shoot the USS Constellation down in Baltimore in pretty much the same way. Also shot the Z bridge in Boston, where the only vantage point was a small foot bridge (unable to get a better vantage unless you go swimming). Bottom line, shooting big items with limited space - wide angle with possibly some stitching.
- Here in Arizona there are quite a few of large rocks/mountains, and even in a large desert, there are limitations from where you can shoot for various reasons. Two areas for example - Superstition Mountain (Lost Dutchman State Park) and Cathedral Rock up in Sedona. There are specific locations if say you are going to shoot the Milky Way over these, where the things are so massive, coupled with the location limitations (shot angles, time of the year, etc.) that force you into certain locations. Yes, you can stitch with longer focal lengths, but there are also reasons why shooting panels also works out a bit better.
Originally posted by mikeSF i always say in my workshops, if you go TOO wide, you'll make a molehill out of a mountain. Use sparingly.
Similar with night sky shooting. A greater FOV captures more stars but they lose detail and become much less pronounced in the composition.
Yes - I agree and often observed here that wide angle lenses push back the center object in order to make room to pull in everything around the edges. A perfect example of this would be the Mittens in Monument Valley. Individually they are impressive, however as a group they are even grander. Telephoto stitching is really the only way to go. Essentially matching the lenses to the situation with a supporting technique.
Wider works for the situations where it works well. And - when it doesn't it fails miserably.
Going back to the West Fork, what I'm trying to do, that I didn't accomplish (failed) on this outing at all - was looking at the best way to capture the high narrow canyons (not really slot canyons like the upper & lower Antelope Canyons), but the narrow high wall (200 - 300 feet high, and perhaps 20 feet wide) canyons with the subway washouts that are located here in Arizona and up in Zion in Utah. I've seen a number of images where folks go just for the subway washouts (impressive in themselves) - which really does not capture the context of the canyon.
Stitchable with a longer lens, absolutely. However, wide angle lenses should work pretty effectively in this environment since the view that you are shooting is literately right in front of you - within a few feet (with plenty of foreground anchors). Couple that with the intense varying colors of the sandstone - up against the green of the trees and shrubs, and you should have a stunning shot. Then with Fall starting, you have the reds, oranges and yellow leaves for about a week or two. Then there is the onset of winter with the first snows here and the white of the snow on the trees (left over fall colors) against the layers of sandstone. With all the hikers and world class photographers hitting this spot, I would think that I would be seeing a lot of WA/UWA similar shots. But I don't. There is probably a reason, I'm thinking in that it just may not "work" well. The folks from Arizona Highways have been shooting this particular area for nearly 100 years.
What I am struggling with is evaluating what is going to work best - and what to acquire next. As I posted, I was really surprised with the width of the 20 on the K1. The 15-30 has a field of view of 111 degrees with the 8-16@8 on a crop sensor at a FoV of 114 degrees. Pretty equivalent, but the K1 increases the available resolution by a factor of 2. In thinking about this over the last few days, I think its just the difference of perception that I am seeing between the K1 and my K5 - and just being so use to a crop sensor. Anyway, I am going to try again and take more time. My wife was sitting in the car in the parking lot wanting to get on the road to Flagstaff for dinner - which didn't help.
