Originally posted by Tony Growden Hi all.
I have just purchased a K-1, and Grip and it is still on V1.00 program.
I have downloaded the V 1.42 update but just want to check that it is ok to update to this direct from V1.00 or should I install all the others. Getting old and confused.
Also is there a link to some basic settings just to start with out of the box. I am sure I saw one here somewhere.
Any help greatly appreciated as this thing is a nightmare to take in after not having a camera for about 5 years.
Thanks in advance
Regards
Tony
G'day Tony,
Congrats on the new K-1, it's an awesome camera and I'm sure you'll enjoy learning how to get the most out of it, especially once you see the images you can capture with this beastie.
Now to answer your first question, the firmware updates are cumulative so you will be fine to load the latest without having to go through the earlier versions. Please note, there were some cool updates added in v1.40. These will be in the latest version anyway but the addendum to the owners manual may not be. Have a scout around the Pentax update page for it, it's only a couple of pages from memory but it is handy for where to find things like the electronic first curtain shutter for live view and the night mode for the LCD screen. Both are really handy.
For settings on the camera itself, your owners manual will be a great friend. There's a lot of functionality in this camera, and determining what you need is a matter of knowing what is available and where to find it. For example, the drive mode is selected by the upper button on the four way controller, however if you're in AF mode you will only be moving the AF selector around when using the four way controller instead of getting to select single frame or constant, mirror up etc. Just above the four way controller is a small button which switches between the two options. The instructions will explain it all.
The K-1's third dial is something to consider when setting up so it provides a short cut for your style of shooting. Typically I leave it on SR on/off to save time when going from hand held shooting to using a tripod. Other times I use it to save going into the drive mode for bracketing and constant shooting, but each to their own for this one.
When I got my K-1 I had left the frame size in auto this meant that my DA70 LTD and DA* 300/4 would default to crop mode. I didn't want this so I set my camera up with full frame as the default.
Look at setting the camera up for how you want it to write to the SD cards. This is personal again but I use sequential with 2 x 64GB cards. Others have images written to both cards as a back up in the field. The size of your cards and your style of shooting will determine what is best for you.
Also consider what speed you want images to be written to the card at. Some setting in the camera will slow this down so refer to the manual or the posted K-1 review for these. Again your type of shooting will determine the relevance of this or not but be aware, if you're shooting constant-high the buffer fills up quickly and then the camera will lock up. Hence the K-1 gets applauded as a landscape camera but not a sports camera. Having said that I use mine for sports and I just adapt my shooting to try and avoid hitting the buffer wall as much as possible.
I have the electronic shutter on for live view, this will then automatically use ES whenever I'm shooting in LV.
I have the viewfinder setting set up after testing each option, this is a personal thing but it's worth testing each option to see how it fits you.
Familiarise yourself with the LCD brightness setting (bottom button on the 4 way controller). This is handy in bright light and low light but you do need to get into the habit of monitoring the histogram to avoid being misled by what you see on the LCD when using the LCD brightness adjuster. For example, if I'm shooting in bright light and set it to +1 or +2 I may underexpose if I don't keep an eye on the histogram.
Get used to scrolling the info button, this will adjust what's on the LCD screen and gets you to the area where you can adjust some items without going into the menu and also set the status screen. I mostly leave the LCD screen on default but from time to time turn the LCD off. When reviewing an image the info button is again used to access the viewing options. I tend to switch between the standard info display and the RGB histogram.
I could go on, but for now I will leave you with two very important things. The first I've already mentioned, as much as it's a pain in the bum, read the manual as this camera can do so much and is very flexible in how you can set it up. The second is to test your lenses for AF performance. There's lots of examples of people thinking there was a problem with their camera/lens but lots of people have had to fine tune the AF, me included. There's plenty of info on how to do that in the forums including a feature by the PF staff. So if you seem to be getting soft images, don't despair it could be just a need to fine tune AF.
Good luck with it all mate and don't forget to share some pics from time to time.
Tas
