Originally posted by pschlute
It is related to the operation of the little button abover the 4 way controller. One mode means you have to press the button to enable use of the 4 arrow keys to move the focus point, the other mode means you have to press the button to disable the arrow keys for Af point and revert to normal funtcion
So from what I gather, Type 2 makes it so that even if the 4 way controller is in the mode that is
not currently in directional focus points (ie Scene, WB adjustment instead etc), then when you turn
off the device and back on then it boots back up to forcing the 4 way controller to being back to being focus point selector and not where it was last left off (ie scene, WB etc).
With Type 1 it seems to be whatever the four point controller was last used for would be the same upon a shutdown and restart?
So by choosing Type 2, with a power down and back up again it is always set to being AF focus control using the 4 directional pads and never start as being WB, Scene selector etc. This is pretty handy, for those that use Single focus point selector, quickly pick up the camera, turn on and can shoot straight away and use the 4 way directional pad without worrying if its still in WB, Scene mode from when last used etc.
