Originally posted by MJKoski Send me OM-D mk2 and 75mm/1.8 Zuiko. I will be happy to show how it works wide open focus stacked against stopped down K-1 and 70-200 f/2.8 SDM AW (send these too). Olympus has its own PS mode too :]
Here is something to read for starters:
diglloyd blog: The Significance of Automated Focus Stepping for Focus Stacking (Nikon D850) diglloyd blog: Scenes Where Focus Stacking Makes all the Difference
Here is practical example what focus stacking does with wide angle landscape photo.
Whole image as result:
100% unsharpened crop of dead swan's eye from full res image:
100% unsharpened crop from swan's wing feathers:
And finally, 100% crop from that far away island:
In the final image there are 9 frames starting from Loxia 21mm lens' minimum focusing distance all the way to infinity. You see, I get SHARP details from 25cm (Lox 21mm MFD) to infinity @ f/8. No way this would have been possible with conventional stopping down, not even f/256 would have worked (total diffraction mess). Canon 24mm TS-E mk2 could work but it is on the edge requiring huge tilt and thus dropping its resolving power considerably. I could have taken this with m4/3 and 75mm lens far away and by using focus stacking it would absolutely demolish stopped down FF setup with 150mm lens. This method is absolutely available to anyone, from beginner kits to $$$$$ setups. Fun things is, K-70 with kit lens will trash K-1 with 24-70 this way and anyone can do it. But those having K-1 and high IQ lenses can also use this. And why should they NOT? Live and learn.
You do realize you showed us an interesting picture but you didn't prove a thing. There's no comparison image taken same time and same light using a hyperlocal setting
Quote: 100% unsharpened crop of dead swan's eye from full res image:
Ya, that's awful, do you have a better example? That low light capability just is bad. It does make the point however that you aren't going to be able to draw up shadow detail from a smaller sensor, stacking or not.
I notice your swan wing is taken from the centre of the frame, where any camera would be sharp.
The distance part of the image is not sharp at all, I'm really not sure what you are talking about here.
I never said there weren't uses for stacking. I said if you can do it with hyperlocal it isn't necessary. And I gave an example of an instance, (macro,) when stacking was your only option. SO, you're arguing points I'm not disputing, you're providing examples that aren't impressing me at all, and you've used an image that goes beyond the capability of hyperlocal focussing, and is therefore irrelevant to the conversation. But at least you got to show off your new toy. That's always a bonus.
Doesn't including a dead swan in your image make it a still life not a landscape? So, I'm also a little dubious of your photographic nomenclature. There's a lot to disagree with here.
I have many razor sharp hyperlocal images, I'm not going to mess up my flickr stream posting pixel peepers. Sorry.
You're acting like a bit of a hot shot here, I'm not seeing why. Was that supposed to impress me?
---------- Post added 12-04-17 at 08:39 PM ----------
Originally posted by stevebrot Me neither until just yesterday with the Wikipedia entry on "Hyperfocal distance". It has some strange properties including something called "incremental depths of field"...sort of a Fibonacci series of DoF based on the hyperfocal.
We used to use "hyperlocal" in the studio all the time using the 1/3rd in front 2/3 behind metric to set our focal point and place an object correctly fully in focus in the frame. Using large format it's pretty critical concept for product photography.
