Show Printable Version 4 Likes Search this Thread
12-07-2017, 03:33 AM   #31
QuoteOriginally posted by 6BQ5 Quote
What is the sharpest K-mount lens + K-1 combination available? Is it the D-FA 28-105mm at 70mm and f/8?
There is very, very little on the market in any mount that can beat the Samyang 135mm F2.
And whatever is able to beat it, will do so only by a tiny margin which I bet not a single user in a forum would ever be able to tell even in direct side-by--side visual tests on real world subjects.
12-07-2017, 04:49 AM   #32
Zeiss 85mm zk. Just an amazing razor.
12-10-2017, 05:21 PM   #33
sbh
sbh's Avatar
How sharp is the D FA 100 WR on the K-1? Or the D FA 50 f/2.8 Macro?
The 100mm WR is sharper than the DFA*70–200 and others if you consider that it has much less falloff towards the edges and through different apertures. In the center at f/8 there is no difference but at f/4 in the edges it gets ahead quite a lot. The 70-200 has better colours though. I compared them with the DA*55, DA 35ltd, FA43ltd, 24-70 and 60-250. I don‘t know about the 50mm macro, I have never used it.
12-10-2017, 06:39 PM   #34
pres589's Avatar
Surprised that the Sigma 180 macro hasn't been mentioned yet.
12-10-2017, 07:19 PM   #35
Sandy Hancock's Avatar
The Sigma Art 35/1.4 is the sharpest wide open of any lens I've used.
Stopped down a bit the FA31, FA43, DA*55, DFA100WR, DFA*70-200 and DA*300 are more than sharp enough for anything I can envisage.
Conversely, the Lomography Daguerreotype Achromat 64/2.9 is easily the unsharpest lens I've used
12-11-2017, 02:44 AM   #36
MJKoski's Avatar
I will continue Samyang rampage - 12/2.8 fisheye is the sharpest wide angle I have used in the center of the image. Good copy is good all the way up to the edges but most are plagued with lens skew so that either right or left side is good/bad.
dslr, full frame, full-frame, k-1, k-mount, k-mount lens, k1, lens, pentax k-1
645Z + FA 645 55mm: Sharpest f-stop at f8 or stop down? Hyperfocal issues.... steve645z Pentax Medium Format 31 01-09-2017 08:08 AM
List of each lense's sharpest f stop? davidreilly3207 Pentax SLR Lens Discussion 7 07-05-2015 11:46 AM
Sharpest Pentax mount lens for under $400? OldNoob Pentax SLR Lens Discussion 21 12-02-2013 07:08 PM
Sharpest lens in Pentax Mount HoBykoYan Pentax SLR Lens Discussion 27 06-30-2010 01:56 PM
Sharpest lens, any brand, ever? falconeye Pentax SLR Lens Discussion 48 03-24-2009 04:27 PM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
