12-08-2017, 11:59 AM   #1
D-BG6 battery grip not fire shutter on Pentax K-1
Dear Forum, just got a Pentax K-1 silver edition with grip which I am truly delighted with. Not sure what I am doing wrong but shutter will not fire when using the grip. All the other buttons and dials appear to work. Any ideas what I am doing wrong? best wishes Mike
12-08-2017, 01:11 PM   #2
QuoteOriginally posted by summiteverest Quote
What you are doing wrong is to assume that this is a user error while it is something to deal with the after sale service of who sold you the equipment.
12-08-2017, 01:30 PM   #3
Worried I have made a truly obvious mistake and not set something. Just wanted to ask forum before I contact camera shop. Any ideas and help much appreciated. best wishes Mike
12-08-2017, 01:38 PM   #4
Problems with battery grips are typically related to bad contact between the grip and camera connection. Cleaning could help. Other than that, I'd have the grip checked with another camera, to confirm if the problem is on the grip or on the camera, camera shop could do the check if they have a K1 in spare.
12-08-2017, 02:10 PM   #5
Is the power switch on the grip set to "on"?
12-08-2017, 02:14 PM   #6
If the power switch was Off, other buttons of the grip wouldn't work (tested on my own K1+grip).
12-09-2017, 04:37 AM   #7
Thanks you are quite right. I tightened it a bit more and it worked. Have spotted a very slight gap between the grip and camera base plate where I can see all the way through. Is this usual? best wishes Mike
12-09-2017, 04:38 AM   #8
Thanks had set both to on. Suspect it was just not tight enough.
12-09-2017, 04:39 AM   #9
Yes totally right. Do you have any gap between your grip and the K-1 body? I can see a slight gap and can see all the way through.
12-09-2017, 07:39 AM   #10
Yes it is.
d-bg6 battery grip, dslr, fire, fire shutter, full frame, full-frame, grip, grip not fire, k-1, k1, pentax, pentax k-1, shutter, shutter on pentax
For Sale - Sold: Pentax Battery Grip D-BG6 For The K-1 (With Accessories) hgbisel Sold Items 2 08-29-2017 12:29 PM
Issues with my Pentax K-1, D-BG6 Battery Grip Let me know if yours is like mine? kraigg007 Troubleshooting and Beginner Help 15 07-09-2017 07:35 PM
Pentax BG6 battery grip JENSEN7474 Troubleshooting and Beginner Help 4 04-18-2016 09:47 PM
All times are GMT -7. The time now is 04:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
