Originally posted by wanderer2 To the OP: When I purchased my K-1 I also purchased the Tamron 28-75, which you have, and the Tamron 70-200, which you are planning to buy. I purchased these two because of financial limitations and considered them both temporary, planning to slowly add primes as finances permitted (so I'm working in the opposite direction that you are). My use is exclusively for landscapes. My assessment of the 28-75 is basically th same as yours - good but not great. However, the 70-200 has been a very pleasant surprise - it's image quality for my uses has been great. Most of my use has been at the longer focal lengths and the sharpness is impressive. I have a 20X30 print shot at 200 with about a 1/3 crop and the sharpness is remarkable. Thus, although I may eventually buy primes in this focal range I am absolutely keeping the 70-200. If you do buy one I think you will be happy with it. Mine is the version prior to the new G2 version which is said to be even better in reviews but I'm not sure
if the G2 is available in Pentax mount. I hope this is of some help.
Neither G2 or G1 are available for K-mount. I believe the only Tamron 70-200 available for K-mount is the older Ld Di Macro. I think last 2 Tamrons have optical stabilization that wouldn't be necessary with most of the Pentax cameras
